07-05-2011, 04:27 | #4 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Nepal
Member: 1061924 Status: Offline Sonork: 100.1612111 Thanks Meter: 95 | info logs here: MCU SW : V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. APE Core: V 5.0737.3.0.1 13-09-07 RM-84 (C)Nokia APE Var : V 5.0737.3.0.1- 12.01 13-09-07 RM-84 (c)Nokia. Product : Nokia N70 Prd.Code: 0539240 Bpr.Code: 0536420 Prod.Sn : CPI527473 HW Vers : 7003 APE HW : 256 APE Adsp: 16054 EM RETU : 32 EM TAHVO: 53 RFIC Ver: 150a160f DSP Vers: rolf_05wk07v29p1 LCD Type: 8618268 IMEI : is ok SL Serv : SIMLOCK SERVER VERSION 58 SL Conf : 244-07-00000000000 SL Prof : 0000000000000000 SL Count: 00 00 BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: Nokia Test;Finland |
07-05-2011, 07:21 | #7 (permalink) |
Freak Poster Join Date: Oct 2010 Location: !!!Suck Me I Know You Can!!!
Member: 1421351 Status: Offline Sonork: 100.1605689 Thanks Meter: 143 | yes, i know its HARDWARE PROBLEM BTW do you know selftest function for WHAT??????? just to inform: selftest function to detecting HARDWARE PROBLEM via CBUS, for easy diagnostic,safety ways and shortcut much time than measuring voltage,rehot,reball or ETC Thanks |
07-06-2011, 10:12 | #8 (permalink) |
Member: 1061924 Status: Offline Sonork: 100.1612111 Thanks Meter: 95 | logs:: CDSP_RF_supply test= unknown result RX IQ loopback Test= unknown result Rx PLL phase lock test= unknown result. i dont what does these mean but sure that all other tests are PASSED. ANYBODY PLZ HELP ME. |
07-06-2011, 12:21 | #9 (permalink) | |
Member: 1421351 Status: Offline Sonork: 100.1605689 Thanks Meter: 143 | Quote:
REPAIR HINTS.... 1.Check voltage needed for HINKU ic a- VBAT 1 for HINKU C7501 = 4V b- VR1 C7504 = 2,8V (Measure it When do searching Manual or Call 112) - RXRESETX at J7515 = 1,8 volt *If at Point a have no voltage,mean the ways is broken, make jumper from VBAT NEAR this component that have same voltage 4V OR from battery connector + if you confuse ** if at point b have no voltage,you can check retu VR1 at C2214 -if retu have voltage mean the ways is broken,make jumper from C2214 to V7504 -if retu VR1 at C2214 have no voltage then you can CHANGE retu IC Short and shortcut explanation hope will solve your problem, if you confuse or have a problem you can contact me on SONORK BR | |
07-07-2011, 06:32 | #10 (permalink) |
Member: 1061924 Status: Offline Sonork: 100.1612111 Thanks Meter: 95 | thnk u sir for reply but i could nt get success.frm ur advice no.A is ok. No.B also seem ok but i cannot find v7504 in the board. i also changed 2n2 capacitor bu tno success. again 3g showing insted of network. |
07-07-2011, 07:27 | #11 (permalink) | |
http://forum.gsmhosting.com/vbb/f528...ml#post7504284 | |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
