10-20-2007, 05:26 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: http://meo786.forumotion.com/ Age: 50
Member: 465162 Status: Offline Thanks Meter: 683 | Use full codes collection. Nokia 3280, 3285, 3580, 3585, 5185, 6185, 8280, etc Nam Programming: Nam Set: *3001#12345# Software Version: *#837# Software Version: *#9999# Esn Number: *#92772689# Restart Phone: *#75681# Restart Phone: *#75682# Nokia 8887 Nam Programming: Nam Set: *3001#12345# Version: *#0000# Evrc: *#8378# Esn/Data/Timer: *#92772689# SID: *#743# Nokia 8587 Nam Programming: Nam Set: *#626#7764726# A-Key: #8159357022#4579# (26 digits) A-Key: #8159357022#4547# (20 digits) Version: *#0000# Version: *#837# Vocoder: *#3872# Change language: Menu 5, 3, 1 Change DM mode: *#7678# Debug Screen: *#8378# Debug: *#8380# Field Test Menu: *#83788# SPC Unlock, Factory Reset: Full Factory Reset: *#7370# Resets all settings including non-user changeable items (like SPC) NOKIA TEST MODE: 51xx, 61xx, 71xx, 3285, 63xx, etc: 1) Turn on the phone. Press *3001#12345# 2) Scroll up to where it says "Field Test" and choose SELECT 3) Highlight "Enable" and choose OK. Turn the phone off then back on. 4) If the test mode screen does not show up press MENU and scroll down to "Field Test" choose SELECT. Press 0 1 then choose OK. 5) Lower left or upper left number is the signal strength. 6) To turn off the test mode press MENU and scroll down to where it says "Field Test" choose SELECT. Press 0 0 and then choose OK. 3360, 6360: 1) Turn on the phone. Press *3001#12345# 2) Scroll up to where it says "Field Test" and choose SELECT 3) Highlight "Enable" and choose OK. Turn the phone off then back on. 4) If the test mode screen does not show up press MENU and scroll down to "Field Test" choose SELECT. Press 2 1 0 1 then choose OK. 5) Lower left or upper left number is the signal strength. 6) To turn off the test mode press MENU and scroll down to where it says "Field Test" choose SELECT. Press 2 1 0 0 and then choose OK. Note:- Bty must be well charged before you play with your phone. Use all codes @ your own risk. Muhammad Afzal Meo |
same use full codes by samsung | naveedbutt | NSPRO | 3 | 03-05-2010 15:51 |
Use full codes collection fo LG | shashankmobile | Various CDMA/TDMA Cell Phones | 2 | 07-03-2009 16:58 |
use full tip for error code | piyush | BlackBerry (RIM) | 11 | 07-01-2009 02:16 |
Use full codes collection fo LG | shashankmobile | Various CDMA/TDMA Cell Phones | 0 | 06-13-2009 16:16 |
Use full codes collection | meo786pk | Samsung Hardware Repair | 4 | 03-15-2008 09:13 |
