Universal GSM Software Write here for questions about Universal GSM Software. Example: USPU, twinsim, sms-soft, drivers... |
04-22-2018, 14:06 | #1 (permalink) |
Freak Poster Join Date: Apr 2014
Member: 2160706 Status: Offline Thanks Meter: 48 | APK Easy Tool for Windows Features: - 7z Compression-level 0-9 - APK infomation with icon by aapt dump badging - Advanced log viewer, with .txt file selection - Allow path changes in textbox - Apktool.jar version selections - Background workers - Cancel button in waiting dialog box - Clear logs when exit - Compile APK - Decompile APK - Drag and drop file support - Enable/Disable check for updates - Enable/Disable tips and ToolTips - Extract APK / Zip APK - Framework installer with option to change path - Framework tagging - Full environment path support - Full options of decompile and compile - Java heap. Default 1024m - Logs tab - Options to rename the apk file - Quick help - Remember path when closed - Remember window position (SHIFT + Q to reset window position) - Sign APK after compile - Sign compiled APK (If you forgot to sign your compiled APK, you can sign it) - Sign seletected APK (It will clone the selected APK, and sign it) - SignAPK (signapk.jar v1.0) - Smali/Baksmali - Switch between apksigner.jar by Google and signapk.jar by bootstraponline - ToolTips - ZipAlign and more... Download Link : APKEasyTool |
