Originally Posted by rajamtkmaster Hi sir,
I have tried to remove FRP on Samsung SM-G935F and giveing this error.
> Connecting Device OK
Device is connected on COM19
> Detecting Device Interface OK
Device is connected to DOWNLOAD MODE
> Removing FRP
Hangs here and give error.
Details:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.IOException: The I/O operation has been aborted because of either a thread exit or an application request.
at System.IO.Ports.InternalResources.WinIOError(Int32 errorCode, String str)
at System.IO.Ports.SerialStream.EndWrite(IAsyncResult asyncResult)
at System.IO.Ports.SerialStream.Write(Byte[] array, Int32 offset, Int32 count, Int32 timeout)
at System.IO.Ports.SerialPort.Write(Byte[] buffer, Int32 offset, Int32 count)
at (frmMain , String , Int64 , Int64 , Int64 )
at SamFrp.frmMain.LOKE_ImageFlashing(String fn, Int64 BinaryType, Int64 DeviceID, Int64 Identifier)
at (frmMain )
at SamFrp.frmMain.LOKEStartFlashing()
at (frmMain , Object , EventArgs )
at SamFrp.frmMain.Button1_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.6.1086.0 built by: NETFXREL4STAGE
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
SamFrp
Assembly Version: 2.0.0.0
Win32 Version: 2.0.0.0
CodeBase: file:///D:/Samsung/Programme/FRP/Gsm%20%20Flasher%20Sam%20Frp%20Tool%20Pro_BY-SHIKHAR/Gsm%20%20Flasher%20Sam%20Frp%20Tool%20Pro.exe
Protect
Assembly Version: 2.0.20.2
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 14.6.1038.0 built by: NETFXREL2
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Win32 Version: 4.6.1081.0 built by: NETFXREL3STAGE
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
Win32 Version: 4.6.1084.0 built by: NETFXREL3STAGE
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Win32 Version: 4.6.1038.0 built by: NETFXREL2
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.6.1078.0 built by: NETFXREL3STAGE
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Management
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
ICSharpCode.SharpZipLib
Assembly Version: 0.85.4.369
Win32 Version: 0.85.4.369
CodeBase: file:///D:/Samsung/Programme/FRP/Gsm%20%20Flasher%20Sam%20Frp%20Tool%20Pro_BY-SHIKHAR/ICSharpCode.SharpZipLib.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
I am using Windows 10 -- 64 . Please need help.
Thanks
Br, Raja |
