Motorola Old Legacy (EMMI) CD520, CD930, L7089, М3x88 (3688, 3788, etc.), P7389, P7689,T180, T192, T250, T260,T2288, V50, V51, V2288, V3690,V3688 and all Timport, Accompli & StarTack Families. |
11-20-2000, 13:23 | #16 (permalink) |
Junior Member Join Date: Sep 2000
Member: 2118 Status: Offline Thanks Meter: 0 | I think we should soon be using Linux for this type of work, even if it's only a small partition on a windows drive. L8r. |
11-20-2000, 23:08 | #18 (permalink) |
Junior Member Join Date: Nov 2000
Member: 2582 Status: Offline Thanks Meter: 0 | Hey, I've tested the software on diferrent machines. Here are results: Procesor - K6 / 266 1.On an older type Soltek MotherBoard the software works just fine Ecp/Epp 2. On a Soltec U508(I think)MB(so called new genration) the software does not work no matter what I do. I repeat is the same procesor). I just move it from one MB to the other. So the problem is about BIOS on the MB. SoniX |
11-20-2000, 23:26 | #19 (permalink) |
No Life Poster Join Date: Nov 2000 Location: EGYPT Age: 44
Member: 2583 Status: Offline Sonork: 100.88702 Thanks Meter: 203 | Hi All , i tried all things u told me friends , didn't work too .. GSMEN , i tried it before and tried it again " no success " .. do u advice me all to change the Mother Board ? it will work ?? Regards |
11-23-2000, 22:16 | #20 (permalink) |
No Life Poster Join Date: Sep 2000 Location: Netherlands
Member: 2100 Status: Offline Thanks Meter: 40 | Hi Meshozzzzzzzzzzzz.... Last try, I speacialy restarted my computer for you! Here is what you do! Start computer. Press del to enter setup Choose "INTEGRATED PERIPHERALS" Onboard parallel poort 378/IRQ7 Onboard parallel mode EPP Quit AND SAVE!!! RESTART COMPUTER Press F8 to run pure dos Run emaster Give password (emmi) Connect power supply Connect ltp cable Connect phone Turn on phone Press "U" Turn "OFF" phone Phone must be unlocked now... Second tip I had also a problem with cable (ltp) on printer it is ok but on emmi is a problem. So maybee just look for new cable! Good luck GsMen |
11-25-2000, 03:33 | #21 (permalink) |
Member: 2583 Status: Offline Sonork: 100.88702 Thanks Meter: 203 | Hi friends , thanks for all this replies , thank u for u GSMEN , but i swear i tried this more than 10 000 time and didn't work too . same results . i tried another LPT cable and it works 100% too .. also my cable work with Priner and Bdm . WAITINT FOR NEW IDEAS . REGARDS |
11-25-2000, 05:17 | #22 (permalink) |
Freak Poster Join Date: Jun 2000
Member: 1623 Status: Offline Thanks Meter: 1 | hi , Meshoz. Slow down your computer via Program.Some Dos mode Gsm unlock program requires very slow computer.Especially Panasonic Programs.Closing cache only reduces Machine speed not I/O speed.Use MOSLO program to slow down the computer.This program also prevents "Runtime Error ... " while in DOS mode regarding to Machine speed is too high. Best Regards... |
12-20-2000, 13:41 | #24 (permalink) |
Freak Poster Join Date: Nov 2000
Member: 2515 Status: Offline Thanks Meter: 4 | I thing problem is in motherboard or in BIOS. Try to use external ports (usualy 2xCOM, 1xLPT, 1xHDD, 1xFDD). You can get it very cheap now from any old 386 computer. I have got at home one useless ports too. But you have to know the jumpers settings on these boards and you need free ISA slot. It is possible to disable COMs and FDD and HDD and use only LPT port on this bords. Then it will only require one free IRQ level. bye, Igor MRU, CZECH REPUBLIC P.S. I flash only ALCATEL and know nothing about MOTOROLA. |
