Motorola Old Legacy (EMMI) CD520, CD930, L7089, М3x88 (3688, 3788, etc.), P7389, P7689,T180, T192, T250, T260,T2288, V50, V51, V2288, V3690,V3688 and all Timport, Accompli & StarTack Families. |
07-16-2002, 20:34 | #1 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Ireland Age: 54
Member: 10516 Status: Offline Thanks Meter: 1 | V50- bad flash-No power On- Possible to fix it? I have phone, affter bad flashing . No power On. Please let me know,have I chance fix it ? Best Regards Andrews |
07-18-2002, 04:44 | #3 (permalink) |
Member: 10516 Status: Offline Thanks Meter: 1 | Thanks Raino! are you realy know , this box can flash dead V50 affter bad flashing? (not sw ON) Please, can you send me solution . I tomorow make this box order. Thanks and have a nice day. Andrews |
07-18-2002, 16:25 | #6 (permalink) |
Freak Poster Join Date: Feb 2002 Location: china
Member: 9315 Status: Offline Thanks Meter: 0 | what machine do you now to flash ? if you use roemmi, when you plug phone to box, do the led in box light? if so ,prepare the data and flash it ,when flash notice the memory ID and check what models of this memory. some memory is difficult to flash for:28f320c3b. the ID is : 28f320b3b :00898897 (this is easy to be flash) 28f320c3b :008900c5 special notice this id. i get this site back email today about roemmi box. |
07-18-2002, 16:52 | #7 (permalink) |
Member: 10516 Status: Offline Thanks Meter: 1 | Hello Raino, Now I have Roemmi box with moto key. I use Motowin sw. My roemmi has only one led green, if I sw On phone Led change to yellow. But I connect my dead phone, sw On and nothink. I hear about possibily flashing by test points. But I don't have anny info about it. Best Regards Andrews |
07-18-2002, 17:37 | #8 (permalink) |
No Life Poster Join Date: Apr 2001 Location: รำมว&#
Member: 3956 Status: Offline Sonork: galletto3 rules :D Thanks Meter: 55 | :) hi come´on, if phone had bad flash and don´t power on vcc to test point is needed to reflash it, so forget about ´magic´solutions and find test point in board, best regards Invisible |
07-18-2002, 17:49 | #9 (permalink) |
Member: 10516 Status: Offline Thanks Meter: 1 | Thanks Invisible, Please, help me find this test point on pcb, and let me know what I have to do step by step. This job is new for me. Kind Regards ANDREWS |
07-18-2002, 17:55 | #10 (permalink) |
Member: 9315 Status: Offline Thanks Meter: 0 | you can find memory's CE ,usualy the CE is in the pin26 ,if the memory is intel and is tsop packeg. if the memory is BGA, you must check the schematic and find CE. After find out CE ,you can use logic pen to trigg it when flash.this is china's method ,becourse phone' cpu will check the memory if correct or not ,when cpu find the memory is empty ,will download from external ,when ce level is high ,cpu will think the memory is empty. so flash auto. if you no logic pen you can connect vcc to CE and power on phone,when the led light cut the line from vcc. of course we can flash with roemmi i think with same method. or write memory with universal programmer lt48 . |
c65 bad cut, no power on | damuro | Siemens Hardware Repair Area | 7 | 01-04-2006 14:21 |
I need help - repair T20s after flash no Power ON !! | Ved | Old Ericsson Phones & Sony Phones | 11 | 09-08-2005 16:25 |
Nokia 3310 can flash,no power on | gsmsalers | Nokia Hardware & Hardware Repair | 2 | 01-23-2003 19:30 |
t28 bad flashed? doesnt power on | nexusnet | Old Ericsson Phones & Sony Phones | 2 | 12-10-2002 18:57 |
BF31w ver 158 possible to fix it | andrews | BF, BG, TH, BHx Series | 3 | 11-28-2002 22:07 |
