Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
03-28-2007, 14:22 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Morocco-Khenifra
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | Add language to motorola phones without box without TestPoint FREEE INSTALL flashbackup register it (to register go Prog Files\Motorola Tools and run regtool now enter the user and pass) DOWNLOAD HERE WE'LL READ THE LANGPACK FROM THE 1ST PHONE -you'll need to read the langpack from an other phone (which contains needed languages) WITH SAME VERSION LIKE THE OTHER. -PRESS *+#+power to know the version (It should the same version in both phones). CHECK THE BACKUP FOLDER (go Prog Files\Motorola Tools\Flash&Backup 3\backups) AND DELETE ALL FILES TO IGNORE FILES MIXING. 1-RUN F_BACKUP power on the phone (the 1st phnoe) and connect it. 2-Select model >Go Read data >Select SHX check Langpack >Press Read Data Done. NOW WE'LL WRITE THE READED LANGPACK BEFORE THAT READ YOUR PHONE BACKUP (select model--select all--read data) 1-connect the 2nd powered ON phone 2-Select model >Go Write Data >Press Select Flash File >Select the file >Press write data Done Tested succefully on L6. Last edited by jawad8305; 03-28-2007 at 14:34. |
03-28-2007, 15:13 | #5 (permalink) |
Banned Join Date: Jun 2006 Location: Z-LanD
Member: 294953 Status: Offline Sonork: 100.1576570 Thanks Meter: 230 | many thnx for sharing this but u can add language to phone so easy just with RSD LITE and without TP too, just select ur langpack and start writing and it's take less than 2 minutes . WBR RockeRenatoR |
03-28-2007, 17:10 | #7 (permalink) | |
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | Quote:
enjoy | |
Add language to k810i without flashing | Gibilon | Sony Ericsson | 2 | 05-09-2009 20:14 |
Hot to unlock V235 without box and testpoint | lupos | Motorola P2k | 5 | 11-10-2007 05:34 |
can JAFWM changeor add language to XDA phones? | KUBAT1 | JAFWM | 0 | 01-11-2007 15:09 |
after add language to v66 black box ! | makona | Motorola P2k | 0 | 04-02-2003 02:23 |
Need soft to add language to v60!!! Please help! | Morris | Motorola P2k | 0 | 07-03-2002 12:42 |
