Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
01-19-2008, 12:21 | #166 (permalink) |
Junior Member Join Date: Jan 2008
Member: 683727 Status: Offline Thanks Meter: 0 | can someone generate a key for me and post it here please? |
01-26-2008, 21:38 | #168 (permalink) |
Member: 688435 Status: Offline Thanks Meter: 0 | I used flash&backup 3.0.4 to backup my v235; but I can't restore it. The phone generates critical error 84. Using RDS Lite 3.4 I could flash my original t-mobile software. So now, I am using this first flash. Do I need a patch to enable flashing with Flash&backup3? (Some years ago I flashed my e398 with shoey i398 ******* pack, but - I think - first there was a patch to enable flashing or flexing.) Sorry for my bad English, but I hpoe, somebody could help me. |
05-03-2008, 17:18 | #170 (permalink) |
Junior Member Join Date: May 2008
Member: 764607 Status: Offline Thanks Meter: 0 | empty list when select backup file to restore I did a backup of V9 using FB 3.07. It dumped all the CGs under c:\program files\Motorola Tools\Flash&Backup 3\Backups\. It created a sub-dir by timestamp with all the CGx.smg files there for about 52M. Now when I go to Write Data, click on "Select Backup file", it presents a blank menu with header Listview.10, Listview.11, Phone Model, Firmware, Flex...w/o anything to navigate.The only thing can do is click Cancel. How do I point it to the Backups directory? Is it hidden somewhere? Or am I missing something? Thanks. |
05-03-2008, 19:49 | #171 (permalink) | |
Insane Poster Join Date: Mar 2007
Member: 469985 Status: Offline Thanks Meter: 6 | @ALL no more serials sorry! read below post and before you install it is recommended turn off your antivirus and firewall...keep in mind if you choose not to the only other way is to purchase it for a bank breaking 10 u.s. dollars!!! Quote:
i dont use "write data" instead i use "firmwares" it does the same thing... - njoie! | |
05-03-2008, 20:02 | #173 (permalink) | |
Member: 469985 Status: Offline Thanks Meter: 6 | Quote:
make sense NOTE you will have to be under the firmwares section for this to work good luck and happy modding! | |
05-04-2008, 02:06 | #174 (permalink) |
Member: 764607 Status: Offline Thanks Meter: 0 | Do you have a list of correct start address of cg1,2,3,4,7,8 for the plain vanila V9 firmware 9.13.37.R3? Or is there a formula starting at a certain relative base + size(offset)? Please help! I just want to flash the V9 back using those cgs files. |
how to backup pds with Flash Backup 3.0 | hassenmobile | Motorola P2k | 1 | 06-16-2007 11:55 |
FLash & Backup 3.0.0.58 | alvaroc | Motorola P2k | 5 | 12-07-2006 15:18 |
