Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola P2k
Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200
C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980
E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070
P-Series: P280
T-Series: T280,T720,T721i,T722i
V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050.
other-Series: like L6,L7,U6.
Old 01-19-2008, 12:21   #166 (permalink)
Member: 683727
when I try to open the keygen (with firewall & anitivirus off) windows says I don't have the appropriate permissions to open the file
can someone generate a key for me and post it here please?
Old 01-20-2008, 06:11   #167 (permalink)
Member: 529506
i am looking for the file flash for motorola phones...
anybody can help me?
i wanna to remodified my phone -->motorola L7
pls help me
thanks so much
Old 01-26-2008, 21:38   #168 (permalink)
Member: 688435
Question
I used flash&backup 3.0.4 to backup my v235; but I can't restore it. The phone generates critical error 84. Using RDS Lite 3.4 I could flash my original t-mobile software. So now, I am using this first flash. Do I need a patch to enable flashing with Flash&backup3? (Some years ago I flashed my e398 with shoey i398 ******* pack, but - I think - first there was a patch to enable flashing or flexing.) Sorry for my bad English, but I hpoe, somebody could help me.
Old 02-05-2008, 18:47   #169 (permalink)
Member: 68192
I need random & flash backup serial 3.0.7 latest version if anynone have it please post it
Old 05-03-2008, 17:18   #170 (permalink)
Member: 764607
empty list when select backup file to restore
I did a backup of V9 using FB 3.07. It dumped all the CGs under c:\program files\Motorola Tools\Flash&Backup 3\Backups\. It created a sub-dir by timestamp with all the CGx.smg files there for about 52M. Now when I go to
Write Data, click on "Select Backup file", it presents a blank menu with header Listview.10, Listview.11, Phone Model, Firmware, Flex...w/o anything to navigate.The only thing can do is click Cancel. How do I point it to the Backups directory? Is it hidden somewhere? Or am I missing something?
Thanks.
Old 05-03-2008, 19:49   #171 (permalink)
Member: 469985
Thanks Meter: 6
@ALL
no more serials sorry! read below post and before you install it is recommended turn off your antivirus and firewall...keep in mind if you choose not to the only other way is to purchase it for a bank breaking 10 u.s. dollars!!!
Originally Posted by p0tsm0ke View Post
FLASH & BACKUP 3.0.7 NOW OUT
USE THE BELOW KEYGEN TO GET YOUR SELF STARTED
DOWNLOAD 3.0.7 INSTALL AND USES KEYGEN POSTED IN THE FORUMS WORKS WITH 3.0.7 NO PROBLEM ENJOY ALL
MAIN WEB SITE
DOWNLOAD FLASH & BACKUP FROM THERE SITE
KEYGEN ---> http:///vbb/showpo...&postcount=134
@gianglongtt
i dont use "write data" instead i use "firmwares" it does the same thing...
- njoie!
Old 05-03-2008, 19:56   #172 (permalink)
Member: 764607
Since I have under backups directory a bunch of smg (cg1,2,3,4,7,8) of my V9, can I install smgs using FB3.07 to flash the V9 back? If yes, how?
Thanks.
Old 05-03-2008, 20:02   #173 (permalink)
Member: 469985
Thanks Meter: 6
Thanks.
you will have to select "add" for each CG and enter the correct address which is usually associated with the name of the CG
make sense
NOTE
you will have to be under the firmwares section for this to work
good luck and happy modding!
Old 05-04-2008, 02:06   #174 (permalink)
Member: 764607
Do you have a list of correct start address of cg1,2,3,4,7,8 for the plain vanila V9 firmware 9.13.37.R3? Or is there a formula starting at a certain relative base + size(offset)? Please help! I just want to flash the V9 back using those cgs files.
Old 05-04-2008, 02:23   #175 (permalink)
Member: 764607
Using SHXCodec 2.66, I add all the CGs 1,2,3,4,7,8 in. I attach below the picture shown each CG size, what missing is the start address for each? Can someone help?
Old 05-04-2008, 03:35   #176 (permalink)
Member: 469985
Thanks Meter: 6
Q
how did you back them up???
if you say using f&b3 then simply open the profile for the v9; should be under the f&b3 program folder...
Old 05-05-2008, 19:59   #177 (permalink)
Member: 766374
Hey guys,
Could someone please make a mirror of the keygen, I can't download the one in the attachment of the earlier post by p0tsm0ke.
Thank you!
Old 05-06-2008, 03:14   #178 (permalink)
Member: 469985
Thanks Meter: 6
turn off anti-virus and firewall before you download , extract and run...
Old 05-06-2008, 11:11   #179 (permalink)
Member: 766374
Thanks, that worked.
Old 06-11-2008, 23:14   #180 (permalink)
Member: 423149
Smile Flash Backup 3 + key rejestracyjny
Flash Backup 3.0.7 + key rej.
http://rapidshare.com/files/12178591...y_Rej.exe.html
[IMG] code is Off
how to backup pds with Flash Backup 3.0 hassenmobile Motorola P2k 1 06-16-2007 11:55
FLash & Backup 3.0.0.58 alvaroc Motorola P2k 5 12-07-2006 15:18
Page generated in 0.24070 seconds with 10 queries
