Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
06-13-2006, 09:25 | #1 (permalink) |
Junior Member Join Date: Jun 2006
Member: 290667 Status: Offline Thanks Meter: 0 | Help!! need Full Flash Backup file for motorola v3 I will be thankfull if anyone can she his full flash backup of his V3 phone and if possible PDS back up too. Thanks!! |
06-13-2006, 22:24 | #2 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Nigeria Age: 42
Member: 68752 Status: Offline Thanks Meter: 88 | All you need is a ******* pack and usb-smart p2k tool v3.9 either original or cracked but i used crack to repair mine today after 2 months of the problem. the ******* pack is in .SHX extension therefore u flash it in .shx format as provided in the software. THIS IS HOW U SHOULD DO IT Connect the TP to GND terminal of batt con and let some part of the TP wire outside the phone. Connect ur usb cable to ur phone and the computer, if it makes noise on the speaker of ur computer, it indicats that something has been connected to the usb port, cut the wire with a scissors. U will cut the wire only when u heard a noise on the speaker. After that, drag the ******* pack into the .shx part of the flashing part of the software. All will be o.k. Remember to select V3 razer on the type of phone. Forget about all u're been told about pds repair or this or that. This solution is 100%, i tried it on my phone which went dead two months ago. My regards |
please help i need full flash alkatel c552a for my box alcabull | treo29 | TSMbox+ | 11 | 09-29-2007 04:22 |
HELP! Need v220 Flash Flex files for english! | Jfields | Motorola P2k | 0 | 01-15-2005 14:05 |
Needed full flash backup for 525 | Olexa | BF, BG, TH, BHx Series | 12 | 11-29-2003 01:00 |
Please help... Need t205 full flash bin-file for external programming... | VELCOM BY | Motorola ODM | 1 | 02-26-2003 20:17 |
Help !!!! need full flash for 3330v3.12 | burko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 09-13-2001 23:46 |
