Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
04-21-2006, 19:59 | #1 (permalink) |
Junior Member Join Date: Nov 2004 Age: 49
Member: 94613 Status: Offline Thanks Meter: 1 | L7 unlock help Clip serial: #######, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (L7 iTunes), getting test interface... OK Model L7 Firmware R4517_G_08.C4.1ER Reading info OK Switching to flash mode... OK [S Flash Neptune LTE2] Reading phone boot version... A.20 Boot prepare... failed I am not sure what is happening...any suggestions? Please HELP!!!!! havent been able to unlock any L7s recently..... Last edited by son303; 04-21-2006 at 21:44. |
04-21-2006, 22:17 | #6 (permalink) |
No Life Poster Join Date: Dec 2004 Age: 50
Member: 95476 Status: Offline Thanks Meter: 185 | open the phone remove ....the metal ..slowly....very danger....to touche ....after this neded test poin ....connecte the cable connecte battrie ok after this connecte presse serche in soft smartmoto....after connected with soft disconnect the tp ok.... and just presse unlock via tp ................voila...... existe site for this??.??? http://www.smart-clip.com/support.php www.boot-loader.com |
04-21-2006, 22:32 | #7 (permalink) |
Member: 94613 Status: Offline Thanks Meter: 1 | I have followed that step by step...the problem is not that...it is when it tries to prepare boot to send...it is failing then... not that its not recognizing the phone... |
04-21-2006, 23:45 | #8 (permalink) |
Crazy Poster Join Date: Nov 2005
Member: 196638 Status: Offline Thanks Meter: 0 | Sounds like your not getting the testpoint right Connect testpoint before connecting battery then search in smartmoto Phone should be detected as "S Blank Neptune" and then switch to flash if phones detected as L7 testpoint hasnt worked you mite not need to connect battery atall, you dont with L6`s, havnt tried with L7 |
04-22-2006, 00:02 | #9 (permalink) |
Member: 94613 Status: Offline Thanks Meter: 1 | I am on the right TP...i just tried what u recommended GMN...without battery, smart moto wont recognize the phone...I am using the TP off the picture from boot-loader.com...ver2...i dont kno what else i can do? |
04-22-2006, 01:20 | #10 (permalink) |
Member: 196638 Status: Offline Thanks Meter: 0 | there are 2 diff testpoint pics for L7, somethings not right you mite have the correct testpoint but for some reason its not making the contact correctly. keep trying untill phones detected as "S Blank Neptune" then remove test point. and unlock |
04-22-2006, 18:04 | #11 (permalink) |
Member: 94613 Status: Offline Thanks Meter: 1 | but if the tp wasnt right or making a connection, then smart moto wouldnt even recognize the phone at all right? it would just say no phone found...Is anyone else running into this problem or any problem unlocking the L7? Please help...thanks |
motorola L7 no display after unlock help !!! | lesansan | Motorola Hardware Repair | 14 | 12-31-2007 12:06 |
L7 unlock help !!!!!!!!! | DigiCell | Smart-Clip | 10 | 03-01-2007 13:35 |
L7 Unlock help | ckadrhanshaw | Phone Unlocking Codes & Maps | 6 | 02-11-2007 18:11 |
Help with L7 Unlock | ckadrhanshaw | Motorola P2k | 0 | 02-10-2007 20:03 |
Motorola L7 unlock by usb-smart help!!! | GOLAM | Motorola P2K (USB-Smart) | 16 | 03-23-2006 00:19 |
