Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
04-11-2007, 06:19 | #1 (permalink) |
No Life Poster Join Date: May 2005
Member: 143889 Status: Offline Sonork: 100.1584685 Thanks Meter: 341 | Need V360 flex file for 900Mhz and is it possible to flex without TP????.... |
04-11-2007, 08:07 | #2 (permalink) | |
Freak Poster Join Date: Nov 2006
Member: 390137 Status: Offline Thanks Meter: 28 | Quote:
04-11-2007, 08:08 | #3 (permalink) | |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @sihnam Yes, that is true. @..::Tushar::.. There are many flex files at www.boot-loader.com. Quote:
Best Regards GSMServer team | |
04-11-2007, 08:25 | #5 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Reset of the phone frequency is possible only if the handset hardware allows to do so. It might happen that the process of band changing was successfully completed but after switching the phone off and turning it back on, the band automatically changes to the default one. This means that phone’s hardware does not support customer settings. Best Regards GSMServer team |
04-11-2007, 12:34 | #6 (permalink) | |
Member: 143889 Status: Offline Sonork: 100.1584685 Thanks Meter: 341 | Quote:
sorry Mr. GSM_Support. hardware is not any matter here. all of them is now working perfectly just after writing proper flex Last edited by Softway; 04-11-2007 at 13:49. | |
04-11-2007, 12:44 | #7 (permalink) |
Crazy Poster Join Date: Apr 2006
Member: 254444 Status: Offline Thanks Meter: 3 | Yamp Release 1.0.4 can active 900MHZ easy to use |
04-12-2007, 08:49 | #8 (permalink) |
Insane Poster Join Date: Sep 2006
Member: 341975 Status: Offline Thanks Meter: 24 | here's a couple quad-band enabled flashes for the v360. http://yuetblog.********.com/2006/10...or-v360l7.html these flashes have the field engineering menu enabled, so you can see whether 900MHz is working by looking at the channel numbers. |
04-12-2007, 08:56 | #9 (permalink) |
Member: 341975 Status: Offline Thanks Meter: 24 | in north america, we have the opposite problem. we need to enable the 850Mhz band on european spec v360's. no cellular carrier here uses 900Mhz or 1800MHz. so far, there's been mixed success. some euro v360's seem to have the needed hardware for 850MHz support. and some do not. |
please i need v360 flash file for rsd | nafg | Motorola P2k | 3 | 04-29-2006 16:48 |
Urgent Need V70 Flex file for Conveting 1900 to 900 | kamransohail786 | Motorola P2k | 0 | 11-19-2004 23:11 |
Need original flex file for t720i BAD | bitziz | Motorola P2k | 0 | 06-26-2003 13:53 |
I need flash+flex files for T280 | Gsmgray | Motorola P2k | 1 | 06-16-2002 05:06 |
need german flex file for V51(italian) | John_Doe | Motorola Old Legacy (EMMI) | 0 | 11-15-2000 23:50 |
