Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
04-06-2006, 17:18 | #1 (permalink) |
Junior Member Join Date: Sep 2005 Age: 42
Member: 178426 Status: Offline Thanks Meter: 0 | Proper way to flash SLVR L7/6 I know I insert the TP correctly, since there is no problem using smartmoto to flash the phone with smf file. I need to use shx because I'd like to change the SLVR to chinese. |
04-06-2006, 22:53 | #5 (permalink) |
Member: 178426 Status: Offline Thanks Meter: 0 | doesn't work I tried to flash a language pack (LP0016 from MotoX) to an non-Cingular L7 using RSD 2.5, however around 11%, it said file corrupted. I have tried LP0015and some others: same happen. Any trick to use RSD 2.5 to flash L7 language pack? |
what is the proper way to remove conatct service in 5130? | khm050 | Nokia Base Band 5 ( BB-5 ) | 3 | 02-09-2010 14:05 |
Proper way to UPDATE your Smart-Sam | kushstha | Ultimate-Sam | 0 | 01-25-2008 00:32 |
What is the proper way of flashing | bhart | Smart-Clip | 1 | 08-14-2006 10:32 |
How to Flash a L7 SLVR...... | JosephB73 | Motorola P2k | 2 | 07-11-2006 22:37 |
Trouble flashing SLVR L7 help! | waldog | Motorola P2k | 1 | 05-11-2006 18:05 |
