Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
04-22-2006, 20:20 | #1 (permalink) |
No Life Poster Join Date: May 2003
Member: 29652 Status: Offline Thanks Meter: 43 | V3 Big Problem i flash phone with R374_G_0E[1].40.3CR_lp002C_full_flash now the phone is with white screen and when i try ti flash it again they put SmartMoto 1.18 Clip serial: xxxxxxx, version: 2.23, initializing... OK Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Flash Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 7.E0 Sending boot... Cancelled Security error, make sure clip is properly connected and powered Clip serial: xxxxxxxx, version: 2.23, initializing... OK Searching for phone... found S Flash Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... io timeout Reading phone boot version... io timeout Searching for phone... found S Flash Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 7.E0 This phone does not need "Remove RSA" procedure, you may unlock it with Smart-Clip button Searching for phone... found S Flash Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 7.E0 Reading flash id... Intel-0x0089 Phone group: V30x,V40x,V50x,V52x,V60x Hardware IMEI: 358917003250xxx Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Flash Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 7.E0 Reading flash id... Intel-0x0089 Phone group: V30x,V40x,V50x,V52x,V60x Hardware IMEI: 358917003250xxxx Incomplete chip identification, restore & write functions unavailable Please HELP URGENT |
04-23-2006, 08:24 | #3 (permalink) |
No Life Poster Join Date: Oct 2004 Location: IN ISLAM HEART Age: 39
Member: 85387 Status: Offline Thanks Meter: 78 | did you try to flash it using test point its easy grnd test point then you will see new hardware found S Flash Neptune LTE then flash it with full flash manstr file(flash+flex+java ). and it will work |
04-23-2006, 13:55 | #6 (permalink) | |
Banned Join Date: May 2003 Location: www.CentralMobile.net/vbb
Member: 28188 Status: Offline Thanks Meter: 579 | Quote:
Choukran lol Best regards, Aishur | |
04-23-2006, 14:10 | #7 (permalink) |
Super Moderator Join Date: Feb 2005 Location: United Arab Emirates , Dubai Age: 38
Member: 113928 Status: Offline Sonork: 100.111866 Thanks Meter: 1,838 | u can download the full flash file in this site link www.boot-loader.com registered and login u r smart-clip allow to download |
04-23-2006, 15:08 | #10 (permalink) |
Registered User Join Date: Feb 2006 Location: pakistan
Member: 236696 Status: Offline Thanks Meter: 30 | success i flash my phone by testpoint procedure,with full flash files of "R374_G_0E.40.9CR".MY PHONE TURNS ON BUT ONLY POWER KEY IS WORKING.then i flash it with "R374_G_0E.42.0CR" BUT still same result.whats the problem will someone guide thanxxxxxxxxxxxxx. |
04-23-2006, 16:03 | #11 (permalink) |
Member: 236696 Status: Offline Thanks Meter: 30 | helpppppppppppp frome where i got motox *******pack.plz guide me i m, still in problem bcz i m using smartmoto.how will i clear my phone with smartmoto.guide me.thanx |
04-23-2006, 17:45 | #12 (permalink) |
Freak Poster Join Date: Feb 2005 Location: on earth
Member: 120740 Status: Offline Thanks Meter: 3 | [QUOTE=Dr-mehdi]i was unlocking v3 version 8.26 during removing rsa smart moto put timeout i flash phone with R374_G_0E[1].40.3CR_lp002C_full_flash now the phone is with white screen and when i try ti flash it again they put SmartMoto 1.18 Clip serial: xxxxxxx, version: 2.23, initializing... OK Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Flash Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 7.E0 Sending boot... Cancelled Security error, make sure clip is properly connected and powered Clip serial: xxxxxxxx, version: 2.23, initializing... OK Searching for phone... found S Flash Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... io timeout Reading phone boot version... io timeout Searching for phone... found S Flash Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 7.E0 This phone does not need "Remove RSA" procedure, you may unlock it with Smart-Clip button Searching for phone... found S Flash Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 7.E0 Reading flash id... Intel-0x0089 Phone group: V30x,V40x,V50x,V52x,V60x Hardware IMEI: 358917003250xxx Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Flash Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 7.E0 Reading flash id... Intel-0x0089 Phone group: V30x,V40x,V50x,V52x,V60x Hardware IMEI: 358917003250xxxx Incomplete chip identification, restore & write functions unavailable ur log showing boot v. 7.E0 that's u don't need remove rsa |
big problem with my mx key | sshreesai | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-31-2010 10:07 |
6085 big problem | kami1987 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-29-2010 13:42 |
V3 Big Problem | RASHED SAM | Motorola Hardware Repair | 2 | 08-09-2008 18:16 |
v3 big problem nd need solution | smart user | Motorola P2k | 1 | 08-13-2006 13:57 |
V3 Big Problem | kasic | Motorola P2k | 2 | 03-16-2006 21:12 |
