Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
04-09-2006, 14:08 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Age: 52
Member: 58186 Status: Offline Thanks Meter: 5 | v3 keypad not working br |
04-09-2006, 14:22 | #2 (permalink) |
Banned Join Date: May 2003 Location: www.CentralMobile.net/vbb
Member: 28188 Status: Offline Thanks Meter: 579 | Hi mates, If the keyboard pcb is well cleaned (No permanent short), try the keyboard fix flex. It is somewhere in this forum. Best regards, Aishur |
04-10-2006, 22:48 | #6 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Inside Your Mind
Member: 229854 Status: Offline Thanks Meter: 0 | Replace the main keypad flex cable and all should be ok!! This is what you need; http://allgsm.co.uk/product_info.php?products_id=462 Regards BladeGsm |
06-02-2006, 17:34 | #9 (permalink) |
Freak Poster Join Date: Jan 2005 Location: curacao netherland antiles Age: 59
Member: 110006 Status: Offline Thanks Meter: 19 | v3 strange problem friends i have one v3 which the key pad is stuck,when i took the board and put it in another body its working good ,the point is when i changed the good board in the same v3 body the screen is not showing.i have tested the screen is good.any suggestions from the genious in this site?thank u in advance. |
06-06-2006, 08:59 | #10 (permalink) |
Insane Poster Join Date: Jun 2004 Location: california OC , philippines ma Age: 45
Member: 67492 Status: Offline Thanks Meter: 7 | need help my v3 got water damaged i clean board and change keypad flex cable but 8 * 0 # bottons dont work , i put board on a good working phone but i get the same problem so its a hardware problem i dont know witch part to replace , any one kind to help out ans share about this problem |
07-20-2006, 08:53 | #12 (permalink) |
Freak Poster Join Date: May 2004 Location: Kabul - Afghanistan Age: 51
Member: 65945 Status: Offline Sonork: 100.1606747 Thanks Meter: 15 | v3 key pad not working hi guys today i had a v3 with keypads not working ........ boot version 8.26 i removed rsa and then unlocked it manually .............. finally the kepads r working ........... remmember that the mobile was working on the same sim card before also. this prodecure was done only for key pad hanging...... wish u all the best |
07-21-2006, 04:08 | #13 (permalink) |
Crazy Poster Join Date: Jul 2006 Location: Canada
Member: 315510 Status: Offline Thanks Meter: 9 | keypad won't function are general complaint with V3 Razor; 1-please check the MB connector,LCD connector,Camera connector,U-sidekey connector;if anyone of it was liquid or shorted will caused the keypad no function. clean it will solve it. 2-power on and display "the voice-record full" "volum key up and dow",it caused by U-sidekey connector,it's under the Caller ID and easy liquid. clean it or reassemble or rep a new! 3-power on and auto enter browser or wedsite it ccause by MB problen(sfotware problem). 4-if you have another complaint about it please let me know:[email protected] |
07-21-2006, 10:04 | #14 (permalink) |
Registered User Join Date: Oct 2004 Age: 43
Member: 86890 Status: Offline Thanks Meter: 9 | i have keypad problem with key 8 and 2 simultaneously. when i powewr on the phone the key 8 will press itself continuosly and if key 8 is fixed 2 will take its place. have check the keypad and the connector. what could be the possible solution. tks in advance |
01-08-2007, 18:51 | #15 (permalink) |
Insane Poster Join Date: May 1999
Member: 130 Status: Offline Thanks Meter: 2 | I have a similar problem...lcdgot busted, replaced lcd...now keypad not working...if I push any button on keypad activates the camera...please any help would be appreciated.. Ebrahim |
razr v3 keypad not working | Siemens man | Motorola Hardware Repair | 41 | 04-10-2011 23:14 |
V3 keypad not working | usernome | Motorola Hardware Repair | 13 | 03-18-2011 20:50 |
V3 keypad not working | kelvinlim | Motorola Hardware Repair | 44 | 05-22-2007 14:25 |
V3 keypad not work | rachelyna | Smart-Clip | 2 | 04-04-2007 18:43 |
v3 keypad not working pls help | spiddy69 | Motorola Hardware Repair | 1 | 03-07-2006 21:34 |
