Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
07-26-2008, 12:24 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Romania
Member: 315165 Status: Offline Thanks Meter: 6 | v3 only light when i connect the phone to smartmoto it says "neptune".. I've repaired pds.. and flashed the phone 3 times now with 3 different flashfiles.. but same thing.. some ideeas? thanx in advance |
07-28-2008, 09:54 | #2 (permalink) |
Junior Member Join Date: Dec 2005
Member: 208484 Status: Offline Thanks Meter: 0 | v3 only light I had 1 pcs with the same problem, I tryed all flashfiles with MSS4, repair pds, etc.... nothing happend, I rehotting mainboarc(PCB) and the phone start to work. After 1 week, the client turn back: The phone don't start at all. I was try again to rehot PCB, but NOTHING !! Phone totaly dead! So, if you want, you can try to rehot PCB, as I do. |
07-28-2008, 15:46 | #4 (permalink) |
Member: 315165 Status: Offline Thanks Meter: 6 | i dont know... this way came into service... but i-ve tried repair pds.. and flashed the phone with V3b_R37AV3_G_0E.A4.29R_A + overwrite boot and after flash..i pluged the battery... and pressed power... and on display appeard the boot menu ... where down was : rdls sig code error... i-ve flashed the phone again..with different flashfiles.. but nothing.. i only got smartclip ... |
07-28-2008, 16:18 | #6 (permalink) |
Member: 315165 Status: Offline Thanks Meter: 6 | it was and is V3 simple.... only with v3b flashfile can i press power and shows boot menu with rdls sig error... i flashed the phone now with v3 simple flash + repair pds and overwrite boot; this is the log .. : martMoto 3.14 S-Card:******xx Smart-Clip dongle, v 2.08, assigned Smart-Clip: ******xx Europe, initializing... OK Clip serial: ******xx, version: 4.07, initializing... OK Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 0.FF Reading flash id... Intel - 28F256L18B Phone group: A630,E1,E37x,E39x,E55x,L6,U6,V3,V190,V330,V53x,V54 x,V55x,V62x,V635,V80 Hardware IMEI: 358917004844828 IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE 358917004844828 (10).mbk" Login request... OK Writing flash section 4 of 4... 100% (7.51 Kb/sec) Restarting phone... OK Searching for phone... found S Blank Neptune LTE Switching to flash mode... OK IMEI OTP status: locked Repair PDS request... OK Performing PDS repair... OK Writing section0 done Flash completed! Writing flash section 2 of 2... 100% (52.4 Kb/sec) Flash completed! |
07-28-2008, 16:39 | #7 (permalink) |
No Life Poster Join Date: May 2005 Location: MIND MAKING COMPANY Age: 44
Member: 144640 Status: Offline Sonork: nnaeem11 Thanks Meter: 238 | thank u very much for posting the result asap and thats i really like from ur side bro keep it up and help others NAEEM FAROOQUI. |
07-28-2008, 23:25 | #9 (permalink) |
Freak Poster Join Date: Feb 2004 Location: noWhere Age: 45
Member: 52810 Status: Offline Thanks Meter: 19 | I cant remember, i may forgot to submit my post while im at work! here it is again take a look here http://www.motox.info/showthread.php?p=424977 it may help |
08-07-2008, 16:31 | #10 (permalink) |
Member: 315165 Status: Offline Thanks Meter: 6 | i tried flash the phone with scout.. but at first says..that fone is blank,...and something by security zone( i have no security backup), and at the and.. i get an error.. so .. same thing.. some other ideas? pls help |
v3 only light in keypad | kripalu | Motorola P2k | 4 | 03-28-2009 17:18 |
v3 only lights appear | jln310 | Motorola P2K (USB-Smart) | 3 | 03-13-2006 21:22 |
v3 only lights appear | jln310 | Motorola P2k | 2 | 03-01-2006 08:37 |
HELP V3 only keyboard lights up | ticktock | Smart-Clip | 4 | 01-14-2006 17:58 |
Motorola v3 only light keyboard | Carlazos | Motorola P2k | 12 | 01-12-2006 14:37 |
