Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola P2k
Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200
C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980
E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070
P-Series: P280
T-Series: T280,T720,T721i,T722i
V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050.
other-Series: like L6,L7,U6.
Old 04-09-2007, 21:20   #1 (permalink)
gambitjam's Avatar
Member: 113732
Thanks Meter: 90
V3i continue pressing power button
Hello Guys,
I got a v3i (R47A) brought to me dead by someone trying to cut the tp area.
I repair & flash it and its working perfect.
When i was about to give the customer, the phone refuse to power unless i hold the power button continuesly. When ever i live the power button it goes off. Before was ok after the Flashing.
I try testing new keypad, still same problem. I then tried putting the board to another V3i it works great. But when i put any working board on the faulty body it still off when power button released.
what can be the cause?
PS: tested the lcd too and ok.
Old 04-09-2007, 22:17   #2 (permalink)
Member: 137754
Check Battery Connector
Old 04-09-2007, 22:28   #3 (permalink)
gambitjam's Avatar
Member: 113732
Thanks Meter: 90
Old 04-10-2007, 05:42   #4 (permalink)
Member: 390137
Thanks Meter: 28
Originally Posted by gambitjam View Post
Hello Guys,
Did you replace the keyboard with one that have the itunes key??
Old 04-10-2007, 05:52   #5 (permalink)
Member: 80244
Thanks Meter: 49
try to clean the keypad and also check the flex and terminals.
Old 04-10-2007, 21:11   #6 (permalink)
gambitjam's Avatar
Member: 113732
Thanks Meter: 90
I DONNO WAT YOU ARE TALKING ABOUT DIFFERENT KEYPAD WITH V3I & V3ITUNE, BUT I TRIED ANOTHER KEYPAD AND IT WORKED.
I THINK THE FORMER ONE IS BAD OR IT IS WHAT YOU SAID TO BE NOT OF V3ITUNE.
But i'll like you to tell me what is the different between the keypads?
Thnaks to all of you guys for helping.
Old 04-10-2007, 21:55   #7 (permalink)
Member: 92260
Thanks Meter: 843
Try This!
Hello Guys,
I've seen this kind of problem here at the repair shop and believe it or not it could be caused by a defective or partially liquid damaged screen assembly. Remember how the keypad/screen connector is used by the magic clips...well a short in just one of the lines could be causing your problem.
Just replace the screen assembly with a KNOWN good one and test again.
As a last resort try changing the entire keypad flex too.
Also try holding down power key for about 5 seconds and see if the display turns on.
Let me know the outcome.
BillA
Old 04-11-2007, 21:14   #8 (permalink)
gambitjam's Avatar
Member: 113732
Thanks Meter: 90
BillA
THANKS FOR THIS INFOR BUT I HAVE SOLVE THE PROBLEM BY CHANGING KEYPAD.
I NOTICE YOUR OLD MEMBER BUT YOU DON'T POST. PLS BE ACTIVE SO YOU CAN HELP AND GET HELP.
Old 03-29-2008, 09:47   #9 (permalink)
imran tec's Avatar
Member: 135718
Thanks Meter: 5
i flash my v3i with flash file r47a but it was r49 bootloader 0.30 i flash it many times wid r47a but its still same then i repair pds then again flash with r47a but its still same as before stucked on screen bootloader showin only
[IMG] code is Off
lgkg200 when i press power button set is vaibrat no on shani72 LG Hardware Repair 2 01-20-2010 10:03
..::n70 not power on when press power button retu very hot::.. HUM Nokia Hardware & Hardware Repair 13 12-22-2009 11:40
Finally Flash Your Vitel Phones Without Pressing Power Button All the Time !!! Aamir_Zia Multi-Box 7 10-27-2007 14:43
samsung t100 white display when press power button shahjee Samsung Hardware Repair 10 07-30-2005 17:06
T500 worked only with pressed power button Anno Samsung Hardware Repair 0 06-14-2004 21:44
Page generated in 0.20689 seconds with 9 queries
