Motorola ODM BENQ(Acer): C113,C139,C168,C200,C205,C300,C257,C261, T205,T2688,T190,T191,V171,V290 CHIMEI: MPX200, MPX220, MPX300, V690, V878 COMPAL: E360, E365, MPX100, C115, C155 |
07-25-2005, 13:36 | #1 (permalink) |
Freak Poster Join Date: Jun 2003 Location: Bulgaria Age: 48
Member: 32284 Status: Offline Thanks Meter: 4 | c115 problem with charging.. I have 4 pieces c115 with same problem...not chrging..they are brand new..never sell..here is the behavior: when I plug the charger phone blinks and sais one time beep...than goes off...and no charging...also no charging when is powered on..no indication on display.. any one got solution for that problem.. Thanks and regards! sergo_zmeia |
11-07-2005, 09:41 | #2 (permalink) |
No Life Poster Join Date: Aug 2005 Age: 45
Member: 166746 Status: Offline Thanks Meter: 86 | HI.. Im having the same problem with C115 and C116. phone is working fine... jsut does not want to charge, like no charger inserted... is there a fuse to check ??? WBR |
11-22-2005, 06:13 | #3 (permalink) |
Member: 166746 Status: Offline Thanks Meter: 86 | Ok, i found the fuse.... it was shorted. but i killed the phone by heating the shield to remove it... i relised this: DONT heat the shield to remove it, break it off with fine screw driver. |
03-27-2006, 16:53 | #5 (permalink) | |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | Quote:
and can anyone give the schematic of this set? | |
06-16-2007, 22:21 | #9 (permalink) |
No Life Poster Join Date: May 2004 Location: A ROUGH ROAD LEADS 2 THE STARS
Member: 66937 Status: Offline Thanks Meter: 5,053 | When You Plugged Charger in it U5(NCP345) Will Enable U4(P-Mosfet) For Cgarfing If VCHG1 Pin5 Rhan 6.8 Volts. The Precess Restat If Batt VHigher Then 3.4. Pre Charger Crrunt Is Abt 40mA Depands On VBattry... When ICHG is Larger then 1A The Pt1 Will Opand (OCP) Also Remember If Battry CVoltage Above Then 4.35v U104 Will stop Charging....!!!! Regards Munna Bhai |
3100 problem with charging | pali | Nokia Hardware & Hardware Repair | 13 | 05-18-2006 15:07 |
Problem with charging - S35 - unusual | siewa26 | x1x to x45/x50 | 0 | 12-22-2003 08:25 |
3310 strange problem with charging | doberman | Nokia Hardware & Hardware Repair | 8 | 12-04-2003 16:46 |
8210 problem with charging | Falck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-26-2002 23:13 |
Have problems with charging c/s25! | mcmomo1 | x1x to x45/x50 | 0 | 12-14-2000 20:47 |
