Motorola ODM BENQ(Acer): C113,C139,C168,C200,C205,C300,C257,C261, T205,T2688,T190,T191,V171,V290 CHIMEI: MPX200, MPX220, MPX300, V690, V878 COMPAL: E360, E365, MPX100, C115, C155 |
12-11-2006, 21:14 | #1 (permalink) |
Junior Member Join Date: Dec 2006
Member: 409349 Status: Offline Thanks Meter: 0 | Motorola c139 AT commands-problem when I press power button - baud 115200 (r/w flash no problems) press and hold (system on) baud 57600 response in terminal window -- > CPU 3 9 TST_C 3 L1:1419h_P2 TM:405h DSP:3606h DYN:6270h CHECKSUM:7dcbh SPI_task: SPI_WRITE_ABB_EVT receivedspi msg (SPI_ABB_WRITE_EVT) send success 17. [EARPIECE_MODEM] type=0 4SSYSTPCO dl sw_c non_clearcase 12:52:59 26/04/06'\SYSTPCO All tasks entered main loopoMMI PCO % AT (command) OK (response) AT+cgsn (command) (cler) |
12-17-2006, 13:44 | #2 (permalink) |
Junior Member Join Date: Nov 2006
Member: 401715 Status: Offline Thanks Meter: 0 | Is your AT command for a new c139 on Cingular IMEI ...9 series
12-19-2006, 19:20 | #3 (permalink) |
Member: 409349 Status: Offline Thanks Meter: 0 | Hi Yes my c139 is Thanksgiving day deal. I'm using usb to uart coverter (my computer com 4) & 2,5 mm stereo connector you can use windows hyperterminal or other software terminal com 4 ( my case) data bits: 8 parity: none stop bits: 1 hardware flow: none software flow: none dtr controll: standard 1. baud 57600 turn on the phone you shoud recive > CPU 3 9........ 2. baud 115200 press & relese power switch - you shoud recive : öA@ftmtoolerror c139dmtool and you ready to go but I still can't use at commands |
Siemens MC35 Terminal AT Command Problem | eozer | GSM Programming & Reverse Engineering | 5 | 10-28-2014 20:50 |
MOTOROLA c139 Tractfone network problem | odetundun | Infinity-Box | 6 | 02-16-2009 11:44 |
Solution motorola v957 at command error | m_naeem | Motorola P2k | 0 | 10-17-2008 22:12 |
Motorola with AT command? | GekoCH | Motorola ODM | 0 | 08-14-2008 18:54 |
Motorola E770 AT command error | shaheen15 | Smart-Clip | 4 | 04-24-2008 20:26 |
