Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola ODM
Motorola ODM
  • BENQ(Acer): C113,C139,C168,C200,C205,C300,C257,C261, T205,T2688,T190,T191,V171,V290
  • CHIMEI: MPX200, MPX220, MPX300, V690, V878
  • COMPAL: E360, E365, MPX100, C115, C155
  • Reply
    Old 06-01-2004, 13:20   #1 (permalink)
    DrMobile's Avatar
    Member: 5932
    Thanks Meter: 1,694
    MPx200 Unlocking Problem.???
    I have MPx200.. asking for NETWORK PUK (not PIN)
    I have readed the FOLLOWING CODES... using UNIMOTO
    NCK Code: 22599469
    CCK Code: 82397585
    SPCK Code: 64734686
    NSCK Code: 80599408
    CODE00: 60734699
    CODE01: 60715854
    Phone is asking for PHONE UNBLOCK CODE: NEW CODE: AGAIAN NEW CODE:
    what is the solution to unlock it.
    Best Regards,
    Wahab
    Old 06-02-2004, 00:40   #2 (permalink)
    Member: 29222
    Thanks Meter: 10
    NCK Code: 22599469
    CCK Code: 82397585
    SPCK Code: 64734686
    NSCK Code: 80599408
    CODE00: 60734699
    CODE01: 60715854
    Best Regards,
    Wahab
    Try 0000 or 1111
    Old 06-03-2004, 05:17   #3 (permalink)
    gsmuy's Avatar
    Member: 65216
    Thanks Meter: 23
    I´m having the same problem.
    Which code works for this situation?
    have you solved it?
    Regards
    Rodo
    Old 06-03-2004, 06:53   #4 (permalink)
    DrMobile's Avatar
    Member: 5932
    Thanks Meter: 1,694
    have you solved it?
    Regards
    Rodo
    No.. I don't solved my problem yet. Phone is from AT&T.. and now I have flashed it with europian flash.. becuase At&t don't work on 900Mhz.
    but phone is "NETWORK PUK" and I don't know how to open it.
    Best Regards,
    Wahab
    Old 06-03-2004, 07:49   #5 (permalink)
    Member: 29222
    Thanks Meter: 10
    Best Regards,
    Wahab
    I think u need to use the NCK code for the Network PUK and if it still asks u for another code...use 0000 or 1111.
    That's what I used for unlocking an AT&T with a remote code.
    Old 06-03-2004, 08:57   #6 (permalink)
    DrMobile's Avatar
    Member: 5932
    Thanks Meter: 1,694
    NETWORK PUK
    This phone is only accepts SIMs from specific netowkrs, and has been blocked. Contact you customer service center for the unlock block code.
    Unblock code:
    [_________]
    New password:
    [_________]
    Re-type new password:
    [_________]
    i tried everything.. after entering code above i got error
    SIM Failure
    The action you are attempting is not supported by the SIM
    Best Regards,
    Wahab
    Old 06-15-2004, 07:35   #7 (permalink)
    Leo140's Avatar
    Member: 43076
    Thanks Meter: 10
    As I think, PUK code must be provided by the local service provider, in this case mostly cause of user, they put wrong code ( SIM PIN) many time. It happends in my country many time. And this problem is caused of SIM card, not phone, don't try to flash your phone
    Old 06-15-2004, 11:12   #8 (permalink)
    dani146's Avatar
    Member: 3812
    Thanks Meter: 3
    Hi,
    as DrMobile writted here - the requested code is for
    NETWORK PUK. Please read the posts above
    So it was not about Sim PUK...
    WBR,
    Daniel M.
    Old 06-15-2004, 14:20   #9 (permalink)
    evan_silbert's Avatar
    Member: 21920
    Thanks Meter: 10
    Maybe flashing it before entering the NCK changed the NCK?
    As far as I know AT&T MPX phones hav always been unlockable by the NCK.
    Old 06-29-2004, 03:58   #10 (permalink)
    UnlockBR's Avatar
    Member: 26751
    Thanks Meter: 2
    I just typed all 00000000 for new password and it worked... did the same to 2 phones with same result!!! ;-)
    Old 07-18-2004, 09:27   #11 (permalink)
    Member: 63450
    Thanks Meter: 2
    i have mpx 200 AT&T 900-1800 but it doesnt ask for nck.....
    it get into the menu with no service.
    is there any trick to get the nck:
    br
    Old 07-18-2004, 12:09   #12 (permalink)
    Hanukkah's Avatar
    Member: 5246
    Thanks Meter: 9
    You or somebody else might have entered wrong a few times too many. The phone is probably now in bruteforce attempt mode.
    Leave it as with blocked sim and do not touch it for a period of 2 hours... then enter the code and 00000000, repeat.
    Old 07-18-2004, 16:19   #13 (permalink)
    Member: 21920
    Thanks Meter: 10
    br
    AT&T MPX200 is 1800/1900. Your network is 900 and the phone gets no reception!
    It is probably already unlocked...
    Old 07-18-2004, 19:53   #14 (permalink)
    Member: 72951
    Thanks Meter: 63
    Version 2.20 will be out tonight or tomorrow morning which will correct all MPx200 problems.
    Old 07-20-2004, 10:04   #15 (permalink)
    Member: 73986
    Talking
    I have an MPX200. I have been given a SIM unlock code so that I can use any SIM on th ephone. I cannot get to the screen to enter this as like the guys above I get a Network PUK screen. I have keyed the code supplied by my supplier and followed up with 00000000 as the new password. I then get the SIM failure screen which says "the action you are attempting is not supported by this SIM" Can anyone shed some light on how I can progress from this.
    Thanks
    [IMG] code is Off
    Samsung Jet S800 Unlock problem javakiller Z3X-Team Products 8 05-15-2010 12:14
    unlocking problem in MPx200 waqarmunir4 Smart-Clip 12 12-12-2007 15:26
    MPX200 unlocking problem mashraf32 Smart-Clip 0 06-24-2007 15:18
    mpx200 unlock code problem zbomberman UniMoto 2 01-26-2005 17:02
    MPx200 unlock problem! nck:******* kockoo UniMoto 9 09-02-2004 12:17
    Page generated in 0.22013 seconds with 10 queries
