Motorola ODM BENQ(Acer): C113,C139,C168,C200,C205,C300,C257,C261, T205,T2688,T190,T191,V171,V290 CHIMEI: MPX200, MPX220, MPX300, V690, V878 COMPAL: E360, E365, MPX100, C115, C155 |
10-26-2007, 23:42 | #1 (permalink) |
Junior Member Join Date: Oct 2004 Age: 58
Member: 85588 Status: Offline Thanks Meter: 0 | problem of flashing and unlocking Moto F3 I have just upgraded my infinity box dongle and still has managed to flash and unlock C261 using usb data cable instead of the Rj45. Using the usb made my flashing and unlocking worked fluently. I just bought an infinity Rj45 cable for motofone f3 to connect it the box and attempt to flash and unlock the f3. However it gives me an error as follows: COM53 [VC0] selected Device: Motofone F3 Checking data, wait... Action: read information Connect... Phone must be POWERED-ON ! connect method #1... connect method #1 fail connect stage #2... connect stage #2 fail connect method #1... connect method #1 fail connect stage #2... connect stage #2 fail Connect Fail Finished, time used: 35 sec Remove/Install battery now ! COM53 ready the FBUS is switched up and RJ45 connected on left. I suspect it can either be a faulty Rj45 cable or the RJ45 conn from the Infinity box itself. Is there an available usb data cable for F3 that will connect to the usb pc port with infinity box dongle to make flashing and unlocking work. Would you suggest where can I buy it because I only see usb data cable for F3 used by SMART MOTO UNLOCKER. Is this usb cable compatible to use with Infinity box? If you could suggest the model no. of the usb cable, and where to buy it i appreciate it. Infinity box is great,.,. Nonie |
complete process of flashing and unlocking | gsm junction | Various CDMA/TDMA Cell Phones | 0 | 02-11-2010 10:39 |
...:::post here ur problem about flashing and unlocking samsung:::.. | toutou_gsm | Trident/AGERE Platform | 3 | 02-14-2009 21:56 |
im have problem to flash and unlock v225 | delchoni | Infinity-Box | 2 | 05-20-2008 20:48 |
problem with flash and unlock 1110 1600 | shayan744 | Universalbox | 6 | 09-05-2006 17:43 |
gd87 problem after flashing and unlocking | ryumahon | Panasonic | 4 | 07-28-2003 07:40 |
