T19x sevice software Tamper Alert option does not work with t190 a phone killed T19x sevice software Tamper Alert option does not work with t190 ,so be carefull. I've already killed a phone. After that no comunication.Maybe soft writes t191 boot for t190. so t190 can't operate and communicate with any flasher. It comunicates with kima's v7.7 but can't flash cause it is t190 not t191. the worst is that the phone was new and I only wanted to test T.A . option with new working t190 Any Ideas? Any help would be appreciated |
For More Advanced Programe That Has More Repaire Options Contact Me Prvt Plz. |
flash it with dmtools.If mo comunicate,removr backup batery near the lcd & try again |
Elco I 've already the battery trick and no result :) |
Send me phone via "Speedy" - i will write for you new flash |
Or better - post me private your adderess - will drop to you writed IC. |
Very Kind of you m8:) |
@debeliamark thanks |
yes I have same problem.. My T190 dead and DM tools no communicate.. |
I have 2 T190 DEAD after repaire tamper alert with this tools. Any solution here. |
:( Sorry but one solution Makona T190 solution desolder flash another board plug and reflsah and again remove flash again plug. More info search button :)));) |
I've already changed flash of t190 with programed f160 from nokia 3210. But after revive I cant change language or flex 'cause the IC has another flash ID from the original flash and this silly DMtools can't flash it or flex it or change it's imei. I started this thread 'cause I think that there is a software solution. After killing with allt19x TA option phone accept boot mode but can't accept second boot and send boot acknoledge . Some software as omega t191 flasher can communicate in such case but unfortunately only with t191 ( flas IC F320). With proper boot this tool can revive such T190's . I made another experiment-I changed flash IC of T191 with Ic for T190. Does anyone have a solution to downgrade T191 to T190. In most of the cases this is a silly thing but in this case this T191 had a broken flash IC and had only F160 |
