06-16-2006, 21:49 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Age: 43
Member: 126066 Status: Offline Thanks Meter: 3 | final solution for u880 unlock The 1st ITALIAN FORUM of UNLOCK Present Lg u880 FINAL UNLOCK !! New module file is here: http://rapidshare.de/files/23310143/...nlock.bin.html -test menu working -possbility to lock it into 2g mode -possibility to set multiple apn so maybe you can fix mms receiving troubles -everything you can do with test menu Siamo Felici di Presentarvi la soluzione finale x lo sblocco dell'u880, stiamo finendo di uppare il tutto e facendo le guide, non appena sarà finito tutto questo lavoro sara messo a disposizione. We're pleased to present WorldWide: "The Definite Unlocking Solution" for the LG U880. Prog to flash GUIDA : How to UNLOCK u880 Flash the phone with this fw : Firmware to UNLOCK u880 Insert a NO 3 SIM . The phone will display "Usim Locked" Pres "SOS" key WITHOUT any other key. The phone will restart..and it will be unlocked ( sia in 2g che in 3g ) !! Remember : When tou flash the phone, you must select "erase efs". By kller & tutto lo staff di all-unlock The 1st ITALIAN FORUM of UNLOCK Last edited by kller; 06-17-2006 at 13:51. |
06-16-2006, 22:10 | #8 (permalink) | |
No Life Poster Join Date: Oct 2004 Age: 73
Member: 84710 Status: Offline Thanks Meter: 12 | Quote:
This is the definite unlocking solution for the End User, meaning no hassle & headaches. Best Regards | |
06-16-2006, 22:13 | #9 (permalink) | |
Freak Poster Join Date: Feb 2004 Location: cellular land Age: 63
Member: 52236 Status: Offline Thanks Meter: 48 | Quote:
06-16-2006, 22:21 | #12 (permalink) | |
No Life Poster Join Date: Mar 2005 Age: 64
Member: 131621 Status: Offline Thanks Meter: 15 | Quote:
06-16-2006, 22:36 | #15 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Message of William Branham
Member: 239523 Status: Offline Thanks Meter: 210 | Thanks for this post. Please where is the flasher and drivers if needed for usb cable? thanks also is U880 diferent from U8500 sold in France? Thanks Last edited by bamogil; 06-16-2006 at 23:26. |
Final solution of u880 flashig unlocking and downgrading without box | shahabuddin | LG | 35 | 11-08-2010 11:34 |
Final solution of u880 flashig unlocking and downgrading without box | ..::rana::.. | LG | 3 | 02-04-2010 22:36 |
Final solution of u880 flashig unlocking and downgrading without box | transpirit | LG | 0 | 11-25-2009 12:02 |
Final Solution For bb5+ Unlock Contact Retailer | ercie2 | Nokia Base Band 5 ( BB-5 ) | 0 | 04-11-2009 09:23 |
i need to final solution for unlock 2670 2630 whit free whit Mt-Box | IkaMazini | MT-BOX | 2 | 02-18-2008 10:56 |
