10-25-2008, 11:43 | #1 (permalink) |
Registered User Join Date: Oct 2007
Member: 617315 Status: Offline Sonork: Skopje Nord Macedonia Thanks Meter: 22 | flashing LG KF700 Now when i turno on the phone,i have that yellow display! How can i solve this problem? |
10-31-2008, 15:05 | #2 (permalink) |
Member: 617315 Status: Offline Sonork: Skopje Nord Macedonia Thanks Meter: 22 | problem solved!!! the problem is solved!! I enter first in emergency mode with Power+2+5,and then I done the flash.Now the phone is ok,but still locked!! If anyone know how to unlock it? Best regards |
The Following User Says Thank You to nandger For This Useful Post: |
05-25-2009, 16:37 | #3 (permalink) | |
Junior Member Join Date: Jul 2006
Member: 318603 Status: Offline Thanks Meter: 0 | just unlock your phone Quote:
just use Vygis to unlock it if you did't check unlock before click flash button. | |
01-30-2014, 11:29 | #7 (permalink) |
Junior Member Join Date: Oct 2013 Location: Ghana
Member: 2056993 Status: Offline Thanks Meter: 1 | For those still having the refreshing yellow screen, change your usb cable. It is causing the software to conflict with the phone's hardware. I had the same problem. i solved it by changing the usb cable. |
LG KF700 Not connect after flash | GSMBOURGES | LG Hardware Repair | 1 | 10-29-2010 06:05 |
Need arabic flash LG KF700 need arabic flash | nashar | LG | 0 | 01-28-2010 16:43 |
Lg KF700 flash ok file Need [SOLVED] | aukonline | FuriousGold | 1 | 08-31-2009 06:44 |
Lg KF700 when sim insert show only lg mono | aukonline | FuriousGold | 0 | 08-27-2009 17:32 |
yessim not working on LG U960 and LG KF700 | kawazaki95 | YESSIM | 3 | 10-19-2008 00:48 |
