02-14-2007, 19:34 | #31 (permalink) |
Freak Poster Join Date: May 2005 Location: Constanta , Romania Age: 39
Member: 144365 Status: Offline Thanks Meter: 31 | |
02-14-2007, 21:25 | #32 (permalink) | |
Freak Poster Join Date: Feb 2004 Location: Planet Earth Age: 67
Member: 54300 Status: Offline Thanks Meter: 20 | Quote:
Please look at that and tell us what box uare using!!! If u want ur solution works on every box give schematics of RX and TX on each box. http://pinouts.ru/CellularPhones-A-N...s_pinout.shtml Are waiting ur not complicate solution man!!!! Thanks | |
02-15-2007, 04:38 | #33 (permalink) | |
Junior Member Join Date: May 2006
Member: 280622 Status: Offline Thanks Meter: 1 | can't unlock KG800! Quote:
I try it . and I get it. KG800 unlock failed | |
02-16-2007, 19:33 | #36 (permalink) |
Member: 144365 Status: Offline Thanks Meter: 31 | like i just said ''universal pinout'' i believed that you understand pinout for universal box. and is very easy because with this cable you can connect the chocolate trough universal box, the cable from usb-smart usb-rj45 convertor ,vygis box , furious box (all have same pinout) and many more.any other questions computs? |
03-04-2007, 13:47 | #40 (permalink) |
Member: 144365 Status: Offline Thanks Meter: 31 | i don't know the phone and like i said if is same like kg800 same base phone and if the only diferance is the band (if is the kg 800 for america) must work .may be you are right |
03-11-2007, 10:34 | #43 (permalink) |
Member: 54300 Status: Offline Thanks Meter: 20 | Apolux, Hey i have found that the solution works fine with universal box and RJ 45 KG800 cable on PIII pentium processor i've tested on many different machine (fail on 90% new processor PIV and Athlon) and to get 100% success use a PIII pentium old machine. Good works man and hope it can help. Computs |
03-21-2007, 20:15 | #44 (permalink) |
Member: 144365 Status: Offline Thanks Meter: 31 | i'm using a P4 at 3.2 ghz am each time works perfect, anyway thankx for posting your results it is very good knowing that.i haven't test on old machines |
03-22-2007, 00:06 | #45 (permalink) |
No Life Poster Join Date: May 2003 Location: POLAND
Member: 27761 Status: Offline Thanks Meter: 55 | 1) can i use this solution with F2400+enforcer to unlock KU800 (new model but almost same thing) 2) can i use that solution for unlock LG Kg220/225 if yes what model should i use, same F2400? |
How to boot & unlock LG KG800 | dkny_chau | HWK | 46 | 05-26-2009 14:03 |
Peoblem unlocking Lg KG800 | Arthur100 | LG | 3 | 04-03-2009 03:29 |
Can Turbo Unlocker unlock LG KG800? | aarons6 | SE Power Clip & Turbo Unlocker | 2 | 12-15-2006 10:00 |
free software for unlocking lg kg800? | ameriknul | LG | 2 | 10-21-2006 18:18 |
problems unlock LG KG800 AFTER FLASH KG90 | lushuai | VygisToolbox | 1 | 08-22-2006 16:59 |
