03-03-2008, 18:00 | #1 (permalink) |
No Life Poster Join Date: Jul 2001
Member: 5243 Status: Offline Thanks Meter: 80 | How to repair the IMEI to ORIGINAL on KU990 & KE990 when damaged by free solutions In the folder where you have run LGMDP_***.exe from create a folder called "NOT_ACTIVE_____" if it doesnt already exist (without the") Copy your original good NV2 backup to NOT_ACTIVE_____ folder (this will have the IMEI number of your phone in the name) Open the NOT_ACTIVE_____ folder (you need to be able to access this during the process) Press Select port and chose your phone. Press Connect Press download Close the window when it asks you to select files Press download again The software will now start making a new backup You will see a new file appear in the NOT_ACTIVE_____ folder When it starts making the new backup right click on it, click rename and press "Ctrl+C"or right click and copy so that it copies the name of the file. YOU MUST DO THIS NEXT PART BEFORE IT STARTS TO WRITE THE BACKUP BACK When it has finished making the backup DELETE it, Right click on your good backup and click rename and press "Ctrl+V" or right click and paste, so now your good backup has the name of the file you just deleted. Now, sit back, relax, and enjoy the show. Tried and tested by me a few times now, and also seen in action by .:GSM International:. (I fixed his phone remotely http://forum.gsmhosting.com/vbb/show...0&postcount=54) Then he helped "vet" these instructions for me to post here for you lot! |
The Following User Says Thank You to AlexG For This Useful Post: |
03-03-2008, 18:04 | #2 (permalink) | |
Cheater -Don't Deal with him- Join Date: Jan 2002 Age: 48
Member: 8879 Status: Offline Sonork: 100.84016 Thanks Meter: 327 | Quote:
1000000000000000000000000000000000% working, after other more professional ppl tried and failed! Thanks man again! | |
03-03-2008, 18:33 | #5 (permalink) |
Junior Member Join Date: Mar 2008
Member: 717249 Status: Offline Thanks Meter: 46 | .......................I just found out my GOOD backup is overwritten by the wrong backup.......hell, could you post a good .nv2 files? It seems the IMEI is included in the .nv2 files, but Bluetooth address isn't. |
03-03-2008, 20:37 | #7 (permalink) |
Member: 5243 Status: Offline Thanks Meter: 80 | its impossible to overwrite your good backup with a bad backup as the imei that is in the phone at the time is in the name of the file or if the imei is damaged it comes up as the date where the imei should be. |
03-05-2008, 20:51 | #12 (permalink) |
Product Supporter Join Date: Oct 2002 Location: Philippines/Shenzhen, China Age: 58
Member: 16816 Status: Offline Sonork: 100.42691 Thanks Meter: 105 | all I did is copy my backup to NOT_ACTIVE______ folder then restore and it went fine. then you can see imei is back to normal,also the bluetooth) br nlogomaster www.gsm-traders.com |
03-07-2008, 22:50 | #13 (permalink) |
Member: 720789 Status: Offline Thanks Meter: 0 | gennie well Alex do u know how to change the imei number of lg cu500? after unlocking through mtty the original imei is replaced by some other number is it possible to replace it by original? if yes can u plz explain the whole procedure? thanks in advance |
05-18-2008, 11:31 | #14 (permalink) |
Junior Member Join Date: May 2005 Age: 54
Member: 148627 Status: Offline Thanks Meter: 0 | Im getting the same-with u990 I keep resetting the IMEI and Bluetooth back to what it says under the battery then when I go to make back up its writes the info as " IMEI Numbered folder/COM4/Some numbers(date). NV file" When I make "Not Locked Folder" am I to copy the "IMEI Numbered folder" or "Some numbers(date) .NV file" into "Not Locked Folder" ? When Ive tried the unlock it says Successful- yet 02 sim Still not registering yet others are |
05-19-2008, 00:33 | #15 (permalink) | |
Junior Member Join Date: May 2008
Member: 775267 Status: Offline Sonork: dimdim Thanks Meter: 1 | Quote:
Dear AlexG.I have read all the instructions but i get stuck at the point where u say "go to the imei section".Where exactly is that?i hope that u or someone who has done it will respond soon beacause iam cant find network and have no phone 2 days now.Thanks in advance! i should have posted it in the link u give for those with no nv backup but i got confused from my panic!anyway if anybody can help i will be most grateful. Last edited by koke80; 05-19-2008 at 00:39. | |
The Following User Says Thank You to koke80 For This Useful Post: |
alcatel ot c 701 how to repair the imei | rogue_16 | Infinity-Box | 6 | 01-05-2010 07:00 |
how to change the IMEI to original? | kurdlad | Samsung Flashers, Software, Firmware. | 0 | 02-15-2009 15:59 |
Does it take Credits to Repair the IMEI of Vodafone V225. | Moderate | SAGEM JTAG UNLOCKER | 1 | 08-04-2008 16:28 |
how to repair the imei on w880i not locked? | crilova | Seking Server | 0 | 04-18-2008 23:40 |
How to repair the Imei on philips 120 with zealot? | to_deal_with | Wray´s Products | 3 | 08-24-2005 08:18 |
