08-17-2008, 09:03 | #1 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 471557 Status: Offline Thanks Meter: 13 | kg110 unlocking problem here the log : If used non Auto-Ignition cable, press Power-On button Boot Ok, FL_ID : 01 21 00 [SPANSION] 0E BaudRate Set to: 115200 IMEI: 3*********************xx Read [01000000-0100FFFF] Done, 00:06 Cal. Data Saved as KG110_355995-01-468137-5_8172008_35235.bif Unlock Done, 00:06 but sim i put sim card it will hang the unit.......any solution in this the unit is now unlock.. HWK ....pls advice,,, Qsite |
08-17-2008, 11:49 | #3 (permalink) |
Member: 471557 Status: Offline Thanks Meter: 13 | kg110 i all ready full flash the unit in the infinity with new flash file but still same...the unit when boot up you should automatic go to the menu to interrupt if that happen the unit ok but you cannot go to the front of the phone cause it will hang.other one boot up while pressing the key pad display the no# example press the no# 7777777 this will appear in the screen slowly delete the 777777 left it with one 7 last delete the left no# it will hang....but if you not delete it will stay normal........ i dont know why this happen......pls,, advice me....:con fused: |
08-17-2008, 12:30 | #4 (permalink) |
Member: 471557 Status: Offline Thanks Meter: 13 | k110 now ok the phone no ok here the log: i just flash this in the infinity in this flash file.. KG110P40_V10h_***-XX_Dec-28-2006_alchemy.B1P.bin KG110P40_V10h_***-XX_Dec-28-2006_code_w_calibration.B1M.bin good luck to others hope usefull to others..... QsItE. |
LG KG110 Restart Problem | imran_qasim | LG | 24 | 11-30-2010 10:36 |
KG110 unlock in Z3X but have problem.... | ASHRIFF | Z3X-Team Products | 3 | 02-21-2010 18:37 |
KG110 Unlock > Problem!? | bhgsmservis | HWK | 23 | 11-09-2007 14:54 |
LG KG110 Unlock Problem | Preco | HWK | 0 | 07-24-2007 20:59 |
KG110 Unlocking problem | i_am_rocky | Infinity-Box | 3 | 05-08-2007 05:47 |
