04-30-2008, 00:23 | #1 (permalink) |
Major Poster Join Date: Dec 2005 Location: TheMoon
Member: 210210 Status: Offline Thanks Meter: 0 | KU990 Camera fails to start | How to upgrade LG KU990? | Factory menu messed up as mentioned I got Vewty today and the camera fails to start. Logo and 'loading' appears for ages untill phone restarts and I have to remove the battery... if it will help, how can I upgrade firmware/software in LG KU990? Is it possible to do that at home? also I think I've changed something in factory menu because over 50MB is used by unknown data and some weird messages appeared in inbox. I wanted to use factory menu to reset the phone, but no change, the camera still fails to open. Is there anything I can do to fix camera? Thanks in advance. |
11-07-2008, 18:09 | #2 (permalink) |
Freak Poster Join Date: Dec 2001 Location: InnovateK
Member: 8012 Status: Offline Thanks Meter: 124 | I had the same problem , i fix it by opening the phone and plugging the camera connector that was unplugged from the flex. I donīt know if your case is soft or hardware problem , bu if it is hardware give a try and check the camera conector BR AC |
02-25-2009, 09:19 | #5 (permalink) |
Freak Poster Join Date: Oct 2008 Location: ROMANIA Age: 35
Member: 888603 Status: Offline Sonork: 100.1641525 Thanks Meter: 40 | KU990 camera loading... same problem...SOLVED!!!! Open the phone and unplug and plug again camera connector!!! eventualy use some alcohol to clean softly camera conector...now the camera work again!!!!!!!! TESTED!!!! SOLVED!!!!! |
The Following User Says Thank You to gopo_nike For This Useful Post: |
02-25-2009, 09:19 | #6 (permalink) |
Member: 888603 Status: Offline Sonork: 100.1641525 Thanks Meter: 40 | KU990 camera loading... here you can see the KU990 dissasembly: http://www.formymobile.co.uk/viewtydisassembly.php |
02-28-2010, 23:49 | #9 (permalink) |
Junior Member Join Date: Aug 2008
Member: 841960 Status: Offline Thanks Meter: 0 | i have a problem too ... meesed with the phones` EFS and the camera won`t work now ... tell me what to do :| i`ve tried to reflash it with older file systems to create a point from where to update with de update tool . i don`t think it`s a hardware problem because i haven`t dropped it :| please email me @ [email protected] |
After unlock LG KU990 show OPT block unavalaible, how to repair it? | svchost | FuriousGold | 11 | 08-07-2009 10:37 |
Help. Error when trying to enter unlock code on LG KU990 | sarahg85 | LG | 2 | 12-01-2008 21:51 |
how to Panasonic SoftBank 705Px, end lG ku990 | kerug-bali | Infinity-Box | 1 | 07-27-2008 04:39 |
NOKIA 1112 MENU messed up after flashing.....help! | mcecaro | Nokia Digital Core Technology 4 ( DCT-4 ) | 11 | 02-23-2007 20:33 |
Need to know how to add Net Monitor Menu | Beachbum | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-13-1999 18:32 |
