03-20-2011, 19:25 | #139 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: LGE
Member: 57760 Status: Offline Sonork: 100.1579298 Thanks Meter: 3,510 | Hi All, Sorry for Late. P990 HongKong Firmware DZ_LGP350AT-00-V10a-454-XX-MAR-09-2011+0 Follow this thread http://forum.gsmhosting.com/vbb/f177...-t300-1158550/ Flasher, USBMap, and all procedure is same just use A165 Firmware and DLL. GS205 Flashing Procedure 1. Download and Install Leo Tool. 2. Open Leo Downlaod Tool, select correct COM port for your BOX/cable. 3. Click Setting and select firmware in pcs format, software will show waiting, connect phone to BOX/cable and press POWER button, keep pressed till the download agent is finished. 4. Release POWER button and let Leo Tool do the rest. KE500 Flashing Procedure 1. Install and run GSMulti v30 2. Go to Setting(s) > Configuration, select DLL and firmware on S/W box, select UART as communication, select correct port of Box/cable, then click OK. 3. Now click START on main window, when the software says Wait Phone Connecting... connect POWERED OFF phone with battery to cable and press POWER button. GW620 Flasher with Guide 1. Downlaod LGDP2 V36 UMTS Setup and extract, go to LGDP2_31_INCLUDE_LGDP1_Setup folder and install the exe (use serial number). Now copy all the files from DOWNLOAD folder and paste on C:\DOWNLOAD (overwrite if needed). 2. Install LG United Modem Driver, connect the phone to PC through USB cable and let the drivers to be installed. 3. You'll need firmware in DZ format and the correct DLL for your model. 4. Open LGDP2_V36_UMTS (for example) from C:\DOWNLOAD, select UMTS in Division and click OK. 5. Select port (check Device Manager for LG USBModem Port number), you can set a range from easy select or select manually. Select DLL and select firmware in Downlaod Configuration. Click OK. 6. Click START in main window and connect the phone in Emergency download mode. Quote:
GT365_090310.rar | |
The Following 3 Users Say Thank You to nasirahmed For This Useful Post: |
03-20-2011, 21:00 | #140 (permalink) |
Junior Member Join Date: Mar 2011
Member: 1539438 Status: Offline Thanks Meter: 0 | nasirahmed hi thanks for replying, but my problem is I have a LG GT365 and remains frozen on a screen is red when flashing, and probe with a flash file KS360, but as the band of 850 is not used to nothing and ask for your help, I want to see if you can do something, to see if I can do this with multiple GSM LG: http://forum.gsmhosting.com/vbb/f453...t365-unlocked- converter-ks360-900MHz-1800MHz-procedure - 1081795 / I await your response and thank you for everything! |
03-30-2011, 12:16 | #145 (permalink) | |
Junior Member Join Date: Jan 2004 Location: Canada Age: 43
Member: 49222 Status: Offline Thanks Meter: 0 | Quote: But I am not sure what should I do with the fls and bin file, how can I flash it in to my Optimus 2x? I upgrade mine to v10b and found out that it doesn't have the handwriting to I really need to go back to v10a. Thanks x 1000000 WLJ101 | |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Upload & Download Eprom | Lousangeles | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-24-1999 05:45 |
