What do you want from me, then we can find the code. individual short explanation in detail. Is not IC code 95320 I sent you with the information in Is not you just have to find the code from data in you can do whatever you want Tell you what you need to do is to work on a code so I do |
Look at the four pictures I posted, which one looks like yours? ----------------------------------------------------------- Uită-te la patru poze am postat, care arată ca a ta? br How to Read FIS Module ====================== Read internal i2c memory to get original code Pinout: Port2.1 - VCC ( +5V ) Port2.2 - SCL ( clock ) Port2.3 - SDA ( data input/outout ) Port2.7 - GND ( ground ) read as 24c32 |
You want me to say that the presentation of M95320 SMD 24C32 mode yi need to swipe the plate that present I figured it. Did 24c 32 reads as an integrated machine m95320. you are very knowledgeable than me I need someone who knows to respect I put it to me point out some places in the pictures do not understand what they mean I know you write in detail. Is it true that removed the M95320 SMD eemprom bird. ie recite her position 24C32 |
Look at the bottom of the unit, underneath the metal bottom. Which Picture looks like yours? ---------------------------------------------------------------- Uite la partea inferioară a unității, sub fundul metalic. Care imaginea pare ca a ta? br |
No tape in the 24C32 eeprom There are only the code for the M95320 SMD Waiting for your help for the code since yesterday evening I know M95320 SMD code in I read that you say 24C32. My head was at sixes and sevens I was amazed what to do. As you have worked as a 24C32 M95320 SMD eempron As 24C32 have worked as a .BIN download - 2shared aparat footo.rar download - 2shared |
Forget the M95320 SMD completely, the code is NOT in the eeprom. You need to wire the PCB directly to your programmer and read as 24c32. ----------------------------------------------------------------------- Uitați M95320 SMD complet, acest cod nu este īn EEPROM. Ai nevoie pentru a firului de PCB direct la programator și citit ca 24c32. br http://forum.gsmhosting.com/vbb/f179...ml#post9680716 How to Read FIS Module ====================== Read internal i2c memory to get original code Pinout: Port2.1 - VCC ( +5V ) Port2.2 - SCL ( clock ) Port2.3 - SDA ( data input/outout ) Port2.7 - GND ( ground ) read as 24c32 |
20130825_201920.jpg download - 2shared 20130825_201939.jpg download - 2shared I also have this type of I would like you very much If you draw me a diagram in the form of detailed 24C32 EEPROM connection in which the legs bench where I need to do. Drawing you describe would be very happy because they have not done anything like this before thanks to you, will try to. I know If you had a detailed drawing I sent him photographs of the apparatus eemprom in me how you need to establish a connection Describe in detail and in the end it's all I okuyacagımıda le type which calkgen Thank you very much for your trouble Will there be any information that will link to the 24C32 eeprom., or Do I need to install a data 24C32 eeproma. That's then anlayamadım. I made a connection cable eemprom. What do I do then. I also do not need to explain it that way. tenks |
and making them in plate M95320 Do I need to be. If you do not have to be the intrusion. Ie, the plate should be installed on the other M95320 24C32 for connecting bothi. If you do not connect it directly to the code'm gonna find how I got it connected to the 24C32. but I do not think these places tenks |
Wire your programmer directly to these points using lenghts of wire. You have Type 1 unit. ----------------------------------------------------------------- Sārmă programator dvs. direct la aceste puncte utilizānd lungimi de sārmă. Ați tip 1 unitate. Port2.1 - VCC ( +5V ) .. pin 8 on 24c32 Port2.2 - SCL ( clock ) .. pin 6 on 24c32 Port2.3 - SDA ( data input/outout ) pin 5 on 24c32 Port2.7 - GND ( ground ) pins 1-4 on 24c32 read as 24c32 |
Port2.2 = SCL Port2.3 = SDA Port2.7 = GND What is Port2.1 ? oops, i didn't see it writen already :) |
1-24Cxx Emprom like the picture to be connected to the HOLD pin number 7 2-radio will be turned off for. 3-M95320 is mounted on the tape will be for 4-calcgen program, we find t read data from tape tenks |
----------------------------------------------------- Utilizați setarea 24c32 pe programator pentru a citi PCB. br |
short to GND to perform fast FIS reset What do I do with this article, or that place in the picture how to use my reset tenks |
Where you need to tie the HOLD pin number 7 Seat free will to HOLD |
