bin file that you sent to Mr. mgr waiting for the result of tenks |
Please be patient, this file is encrypted and not easy to solve. We are working on thiis and are trying to resolve this quickly :) ------------------------------------------------------------- Vă rugăm să aveți răbdare, acest fisier este criptat și nu este ușor de rezolvat. Suntem de lucru pe thiis și sunt încercarea de a rezolva rapid acest lucru :) (If any other decoder can provide a code for: http://forum.gsmhosting.com/vbb/f179...ml#post9681552 then please help.. thank you) |
Thank you again and again edrim valuable administrator. You saw a lot of trouble for me I look forward to good news from you I wish you success in your work ozkan bora |
With thanks to "Camel131" we have made this dump from your original. Upload this to your radio and use the Code from PM, pass also in PM :) -------------------------------------------------------------------- Cu grație "Camel131" am făcut acest depozit din originalul. Încărcați acest posturile de radio și de a folosi codul de la PM, trece, de asemenea, în PM :) br |
bin file that is sent to tape, you need to transfer it to. Is that what you mean. bin file that you sent me what the code |
YES!! :D ... use code from PM ;) ------------------------------- DA!! :D ... folosi codul de la PM ;) br |
20130826_161941.jpg download - 2shared 20130826_161833.jpg download - 2shared 20130826_161933.jpg download - 2shared Sorry about the state of the PMC was safe at the wrong moment and wrote con |
(Varify) I do not understand what you mean Please write what you want to say in a different way |
Can you "Verify" the dump in this unit? ---------------------------------------------------- Poți să "Verificare" groapa de gunoi în această unitate? br |
I may have another solution... use this dump but set programmer to 24c64 :) The code and password are the same as the last file :) -------------------------------------------------------------------------------- Am putea avea o altă soluție ... folosi acest depozit, dar programator set de 24C64 :) Codul și parola sunt aceleași ca și fișierul ultima :) br |
I'm just sent you open the dump of said code Have you checked you bulabşleceğinizi me the code and asked me to wait a bit I waited for hours and now I'm waiting for you, so I sent the result of what the code dump? incelediğinize göre teybin giriş kodu ne???????? If you want to help me, if you just type the code CODE= **** WAT ?????????? I wanted to sent you the dump file tenks.......... |
All right. told me to do it, but only one last summerç Write to me one by one in the form of 1.2.3 Eeprom 24C64 mounting tape is also necessary to. Sent into the program the eeprom 24C64 dump? Do you mean lunch. summer's everything you do not ask me again. tenks |
Repeat process as before but with new dump set to 24c64 :) ----------------------------------------------------------- Repetați procesul la fel ca înainte, dar cu noua groapa set de 24C64 :) br |
my dear friend, 1 - before, cables hooked up to the plate arranged to 24C32 and the programmer, and I made the connection of these datas precompiled copied tape. 've done so far is it true. 2 - Now do I do the same process again, but the programmer 24C64 datas copy of the tape set it true so far. 3 - copied datas sending to you, you will find the code you tape me, is it true I have written up here All of what I write is correct, please contact me if you just say yes |
