Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
10-04-2006, 04:06 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 41
Member: 108687 Status: Offline Thanks Meter: 104 | Applications for Nokia Symbian 9.1 3rd Edition Phones manage your daily expenses s60Spot on: just like flashlight, turn ur camera on all the time Total Recall: manage ur calls!! |
The Following 7 Users Say Thank You to peterpete_82 For This Useful Post: |
10-17-2006, 03:53 | #4 (permalink) |
Member: 108687 Status: Offline Thanks Meter: 104 | SplashPhoto.v4.21.S60.3rdEditon.Full.incl.Seria [Cracked] SplashPhoto.v4.21.S60.3rdEditon.Full.incl.Serial SplashPhoto turns your smart phone into a mobile digital picture frame. Organize the photos on your phone or memory card with this unique, easy to use interface. * Simple, fast, high quality image viewer * Install JPEG images to internal or external memory, saving precious memory * Organize images using an unlimited number of categories * Send images to other mobile devices via infrared, Bluetooth, SMS, or email * View images in a Slideshow * The Image Browser displays images in List, Detail, Thumbnail and Gallery Views. You can filter these views by Category or Location. * Select an image to view it full screen or watch your images run as a Slide Show http://www.anonym.to/?http://www.upl.../?get=KUDVU5L1 |
The Following 4 Users Say Thank You to peterpete_82 For This Useful Post: |
10-27-2006, 04:28 | #5 (permalink) |
Member: 108687 Status: Offline Thanks Meter: 104 | Igor.Dontsov.Auto.Hang.Up.v1.1.S60v3.SymbianOS9.1. Cracked-SyMPDA Igor.Dontsov.Auto.Hang.Up.v1.1.S60v3.SymbianOS9.1. Cracked-SyMPDA Auto Hang Up is the tool that helps you to reduce call charges. The program automatically hangs up incoming or outgoing call after user specified duration. Don't pay for an extra minute of conversation because of two seconds. Auto Hang Up is the lite version of Minute Beep for S60 3rd Edition phones. Here is what users say about it: Update! Auto Hang Up 1.1 Improved reliability (previous version of the program stopped processing calls under specific conditions) Upgrade is free for already registered customers. Compatibility The program is designed for S60 3rd Edition phones. It has been tested on Nokia 3250, E60, E61, N80. If you know Auto Hang Up works on some other phone, please let me know |
10-27-2006, 04:30 | #6 (permalink) |
Member: 108687 Status: Offline Thanks Meter: 104 | SmartphoneWare.Best.Blacklist.v1.0.S60v3.SymbianOS 9.1.Cracked-peterpete SmartphoneWare.Best.Blacklist.v1.0.S60v3.SymbianOS 9.1.Cracked-Peterpete Automatically rejects unwanted callers. Real-time incoming number analysis and instant reject. Easy to configure and use. Your phone will be always busy for unwelcome calls! Real-time incoming number analysis. When you have an incoming call BlackList application instantly detects incoming number and uses unique algorithm (reverted binary tree) to analyse it and determine if the service has to reject it or not. Regardless of how many numbers/contacts it has to analyse it rejects the call if needed in some microseconds, before your phone starts ringing and disturbs you. * Just busy. Because of real-time number analysis and almost instant call reject all unwanted callers won't even know that they are blacklisted, they will just hear busy tone all the time. * Scheduler. Scheduler makes BlackList your completely automated personal secretary. The service can reject everyone except family member at night, accept only co-workers at business hours on working days, etc. * Real interaction with built-in contacts. When you set up your black lists you can add here contacts from your contact book (not just import phone numbers!) and even more you can insert here groups of contacts. Just create in your built-in contacts application some groups like Family, Spammers, Co-workers, etc and add these groups to as many lists as you need without adding tons of contacts to every list. * Service based application. BlackList is professionally made application and consists from configuration application that you can start like any other application and service module (always-in-memory process). When you have configured the settings you can activate the service and close the configuration application. The service will do all job using really small amount of memory, system resources and absolutely transparent to user. Just configure and turn it on one time and you can forget about it and forget about all unwanted callers as well. Compatible devices: Nokia 3250, Nokia 5500 Sport, Nokia E50, Nokia E60, Nokia E61, Nokia E70, Nokia N71, Nokia N73, Nokia N80, Nokia N91, Nokia N92, Nokia N93 |
The Following 6 Users Say Thank You to peterpete_82 For This Useful Post: |
11-02-2006, 04:29 | #10 (permalink) |
Member: 108687 Status: Offline Thanks Meter: 104 | Odendahl.SEPT-Solutions.Mobile.Task.v1.00.S60v3.Cracked-peterpete Odendahl.SEPT-Solutions.Mobile.Task.v1.00.S60v3.Cracked-peterpete Mobile Task is a native C++ Symbian application to start and stop any other application automatically. With this application, there are thousands of interesting use cases such as starting an application automatically at the morning, shutting down the radio after going to sleep or turning on/of the camera light as a bedside lamp. Many exciting features are available: start/stop of any application time based on predefined durations, a user defined duration or at a specific timepoint comfortable overview of all created jobs load and save of your jobs deletion of jobs application is not closed if memory is low direct start of any application with ok button/joystick |
11-02-2006, 04:31 | #11 (permalink) |
Member: 108687 Status: Offline Thanks Meter: 104 | Ingraal.BlueRadar.v1.10.S60v3.SymbianOS9.1.Cracked -peterpete Ingraal.BlueRadar.v1.10.S60v3.SymbianOS9.1.Cracked -peterpete Lost your partner in the shopping center and he/she does not hear you are calling him/her? Overlooked someone you are waiting for in the ******* or in the club passing by? Late to your classes and cannot find the classroom without knocking at every door? Want to be warned when your boss is approaching your workplace? Or, would you like to play the old "hide and seek" in a new exciting way? (E.g. identify an unknown person whose mobile phone you can detect?) This is where BlueRadar can help you. BlueRadar quickly detects a bluetooth device even if the device is not in the discoverable (public) mode and notifies you when it is near. It is just enough if the mobile phone or other device belonging to the person you want to trace has bluetooth switched on. |
11-02-2006, 04:36 | #12 (permalink) |
Member: 108687 Status: Offline Thanks Meter: 104 | sms accelerator for n80 sms accelerator for n80 this is the most common problem of nokia n80. so slow in sending messagess... this will speed up your sms sending. but it will work after few minutes after installation! |
11-02-2006, 04:46 | #14 (permalink) |
Member: 108687 Status: Offline Thanks Meter: 104 | Sillyant.TiViPhone.v0.125a.S60v3.SymbianOS9.1 Sillyant.TiViPhone.v0.125a.S60v3.SymbianOS9.1 Sillyant.TiViPhone.v0.125a.S60v3.SymbianOS9.1 VOIP THAT REALLY WORKS - A MUST HAVE APP * Internet telephony application and services * SIP softphone dialer * Encrypted VoIP over GPRS/3G * Works with WIFI connections Just to get the idea - we have released a cellphone software that will make your telecommunications more secure and less expensive. If you know what is Skype, TiVi or Gizmo, then you will appreciate our VoIP application that will work on your Nokia telephone just the way it does on your computer. We welcome you to encrypted conversations over cellular phones, mobiles and handys - whatever you call them! It is not just push-to-talk! It is true, realtime, full duplex, encrypted voice-over-IP connection for subscribers of GPRS and 3G networks. Tested on NOKIA N80, N91, N93, E60, E61 and E70 More app info at: hxxp://www.tivi.com http://www.fullmaza.com/forum/showthread.php?t=15445 |
The Following User Says Thank You to peterpete_82 For This Useful Post: |
11-02-2006, 04:49 | #15 (permalink) |
Member: 108687 Status: Offline Thanks Meter: 104 | Advanced Device Locks v1.00 for S60 3rd Edition.Keygen-HSpda Advanced Device Locks v1.00 for S60 3rd Edition.Keygen-HSpda Advanced Device Locks allows you to lock your phone automatically by choosing one of the following options: Always - each time the phone is turned on, it asks for the unlock code. When SIM Changed - the locks are on if the SIM card of the phone is changed. Automatic lock - an automatic lock is switched on after a specified period of inactivity in minutes. Protected applications - this option turns on the device locks if someone tries to access the protected applications. With Advanced Device Locks you have the unique option to choose whether to lock the phone itself, to lock selected applications on it or to combine these two options and lock both the phone and certain applications. The lock code can be changed very easily only with a few clicks. This file contains keygen but needs online connection for activation. Try it and tell me if u succeed. |
The Following 11 Users Say Thank You to peterpete_82 For This Useful Post: |
applications for Nokia N73 and other 3rd generation phones | alex_center | Nokia Multimedia | 12 | 04-26-2010 07:17 |
Encrypt Calls Program For Symbian 9.1 3rd Edition Phones? | lynx77 | Nokia Multimedia | 4 | 12-05-2009 02:58 |
Most hot&Tot wallpaper for Nokia Mobiles s60 & 3rd edition | goyalamit123 | Nokia Multimedia | 0 | 08-10-2006 20:53 |
