Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
03-19-2002, 07:58 | #1 (permalink) |
No Life Poster Join Date: Jan 2002 Location: Bad Cluster Age: 46
Member: 8426 Status: Offline Thanks Meter: 17 | No Startup Logo After Repair imei i flashed my phone 3310 4.19 with full flash iunlock it with eepromtool v3.0 i power it on it accept card but no network after that i make imei repair with the same eepromtool after that phone work good but there is no startup logo please help www.softskiner.fr.st regards |
03-19-2002, 11:27 | #2 (permalink) |
Major Poster Join Date: Jan 2002 Location: Egypt
Member: 8387 Status: Offline Thanks Meter: 0 | Hi If you want your default startup logo come back -Run LogoManager 1.2.4 or any up version -Select Startup logo Option -From the tools menu select Set Logo To Default THAT's IT |
03-20-2002, 20:34 | #4 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Leicester, UK Age: 38
Member: 7252 Status: Offline Thanks Meter: 0 | Use Eeprom Tools to do a full factry reset. Check the factory setting and then it'll do it. Now, if you haven't got a Startup logo, use the latest version of LogoManager (v1.26) to restore the default one or upload your own. |
03-21-2002, 13:13 | #6 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Earth Age: 44
Member: 10281 Status: Offline Thanks Meter: 4 | I had the same problem with a 8210 after flash it 8250 flash I open logomanager find a start up logo and upload to the phone. Was ok but later i make reset logo with logomanager and the phone is ok with the original start up log.work for me why don't for you ! |
03-21-2002, 13:56 | #7 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | There is differences in EEPROM address from one phone version to another!!! For 3210 - you must rewrite eeprom from same version using Hardware programmer or Using some tools via M-Bus (B-Phreak or X-PTO) . For 82xx - there is same problem, but eeprom correction is simple - just use Dejan 1.00b. Debelia Mark |
03-21-2002, 19:41 | #8 (permalink) |
Member: 8426 Status: Offline Thanks Meter: 17 | Solution Found Enjoy 100% hi solution Found just read phone with nokia tool (old tool) in the factory settings click (ui settings) and press apply fs or sw reset open logo manager and Set Logo To Default 100% working |
C160 restarting on startup logo after writing eeprom! | MUNEEB_AKHTAR_RAZA | Z3X-Team Products | 7 | 03-05-2010 17:15 |
E950 no network after repair Imei and Sn | hoangtruongson | Z3X-Team Products | 1 | 10-01-2009 12:09 |
mpx200 hangup on the startup logo after get the codes | XPERT-Cell | UniMoto | 3 | 08-22-2005 12:34 |
How restore original animated startup logo after upgrading & factory reset v5.47 ? | reggid | Nokia Multimedia | 9 | 05-18-2002 20:17 |
