Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
12-22-2006, 22:38 | #1 (permalink) |
Junior Member Join Date: Dec 2006
Member: 412126 Status: Offline Thanks Meter: 0 | Nokia E50 - Useful applications and games for it ================================ Applications: -------------------------------- Best Blacklist Calcium Calculator CoreMp4 Codec DivX Player Handy Clock Handy Keylock Handy Taskman Handy Zip Mobile Rar Opera Papyrus v1.2 ProfiMail v2.60 QReader scanR v1.0 SmartMovie v3.25 Telstra Player Y-Browser v7.5 Live MSN OfficeSuite SmartMovie Converter for WinXP ================================ ================================ Games: -------------------------------- Colin McRae 05 Golf Pro 2007 SE Ice Age 2 MicroForum **** Manga Poker Need For Speed Carbon v4.5.0 Vegas Backgammon Worms v1.9.0 ================================ And here is the link for download: http://www.megaupload.com/?d=7N805N5A |
06-01-2007, 17:19 | #6 (permalink) |
Freak Poster Join Date: May 2005 Location: `HeLL was fuLL,so i came back` Age: 38
Member: 144713 Status: Offline Thanks Meter: 43 | how 2 sign nsigned appz Follow this steps. 1. Register an account on www.symbiansigned.com 2.download https://www.symbiansigned.com/DevCer..._2006_v2.0.exe Create a new folder on your desktop containing the unsigned SIS and the two files from signsis_files.zip. Open the DevCertRequest tool that you downloaded and installed as per item 3 above under Tools. You must now create a name and an output directory for the cert request you will be creating. Give it any name and choose the folder that you created in step 1 for the output directory. Then hit next. On the next screen, check No. Then next to "Private key file" browse to the folder you created in step 1 and give your key file the same name you've been using. Then click on Open. Make the password 12345 and then re-enter it. Populate the required fields on the next screen with any data and then click next. Now you will have to add your device's IMEI number to the cert. Follow the guide in the image below and if you do not know your device's IMEI, enter *#06# on your device in the standby screen. Highlight all of the "Application Capabilities" and click Add. On the final screen simply click Finish. You will now see four new files in the folder you created in step 1 Now go to www.symbiansigned.com and log in Click on the "My Symbian Signed" tab, then click on "Developer Certificates" Click "Request" under "Developer Certificates". Then browse to the CSR file in the folder you created in step 1 Once the CSR is uploaded, simply click on "My DevCerts" in the menu on the left and you will see a link to download your newly created certificate (CER file). Save it in the folder you created in step 1 You now have everything you need to sign your SIS file. Open auto_signsis.bat in MS Notepad. You will see that is currently contains the following: Code: signsis xyz.sis xyz_signed.sis xyz.cer xyz.key 12345 Replace every "xyz" as appropriate. So if your unsigned file (and all of the files you named above) is called "MyApp", then the text in the batch file should read: signsis MyApp.sis MyApp_signed.sis MyApp.cer MyApp.key 12345 Save the batch file (choose Save, not Save As) and exit. Now just go back to the folder you created in step 1 and double-click on auto_signsis.bat. Your newly signed SIS file will be created in the same folder for you to install and enjoy |
06-01-2007, 18:44 | #7 (permalink) |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 941 | ok i have downloaded somewhere this manual but i did't know that you can make all soft signet beacause on manual say make fxeplorer signed..... anyway thnks for replay i will try |
06-02-2007, 09:36 | #10 (permalink) |
Member: 322417 Status: Offline Thanks Meter: 941 | everything ok but when i try to install xxxsigned.sis i get an same error can someone explain why Last edited by Formingus; 12-06-2007 at 10:35. |
Nokia 5800 S60v5 Application And Games Released By Nokia Collection | ashraf_bcs | Nokia Multimedia | 6 | 01-26-2009 18:48 |
Application and Games For Nokia 6600 | panji_millenium | Nokia Multimedia | 9 | 12-28-2005 19:48 |
