Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
04-12-2005, 13:59 | #1 (permalink) |
Junior Member Join Date: Jul 2004 Age: 49
Member: 71449 Status: Offline Thanks Meter: 0 | Oxygen Phone Manager Symbian 2.4.0.5 with Nokia 6680 Only managed to connect up with PCSuite 6.5.. Please Help.. Thanks! |
05-21-2005, 22:06 | #2 (permalink) | |
Insane Poster Join Date: Feb 2004 Age: 52
Member: 54277 Status: Offline Thanks Meter: 0 | Quote:
Changes in version 2.6: ======================= - Added support for Nokia 6680. - Added support for Nokia 7710. - Added support for Nokia 3230. - Improved virtual port search for Microsoft and Widcomm Bluetooth drivers. - Options: Manual Bluetooth COM port setting removed to simplify connection setup. Now you only need to select the Bluetooth driver you want to use. - Options: Now only installed Bluetooth drivers are enabled for selection. - Options: If specific Bluetooth driver is installed but have no virtual COM ports it's enabled for selection but draws as disabled. - Improved Bluetooth connection error processing. - Phone Information: Added ability to load phone images from file and from Oxygen Phone Manager web site. - Phonebook: Now import from vCard files (*.vcf) can import several contacts from one vCard file. This feature can be useful for Palm owners to transfer contacts from Palm to phone. - Phonebook: Added support for Nickname, UserID, WebCall and VideoCall fields. - Phonebook: Fixed bug in speed dial writing. - VCard: Big picture field is now enabled for all Series 60 models. We have been asked about it because this field is supported by SymbianWare Full Screen Caller for Nokia Series 60. - VCard: Added support for Nickname, UserID, WebCall and VideoCall fields. - VCard: All fields are allowed for input, but the fields not supported by current phone model draw with color specified for "Items not stored in phone" in Options. - Main menu: Added "Languages" -> "Download additional languages..." menu item. - Added ability to cancel file upload. - Phone images library is now excluded from installation package to reduce its size. You can either load images when needed using "Download picture" link in Phone Information window, or download and install Oxygen Phone Manager images library available at http://www.opm-2.com/download/symbian_pictures.exe. - Fixed bug with "Monitor program found on your computer" on some Windows 98 machines. - Phonebook: When sorting by Name column, Prefix and Suffix fields are ignored. - Phonebook: Fixed bug with Prefix and Suffix fields handling for Nokia 9500/9300. - Messaging: Added ability to select SMS Center when creating new message or replying/forwarding. - Splash window: Fixed bug with displaying international symbols. - Gallery: Bug fixed: Files information in main Gallery window was not updated after reading all Gallery files. - Gallery: Current extension is always preserved when renaming file (e.g. if you renamed "image.gif" to "newimage.bmp", the new file will be "newimage.bmp.gif"). - Gallery: Showing system "Open with..." dialog when trying to open file having no associated program. - Gallery: Now you can cancel files write and delete process by pressing Esc. - Gallery: Now you can drag&drop files between folders via Phone Explorer(tm). - Gallery: Expanded/collapsed state now preserved for all nodes in Phone Explorer(tm) after reading, adding or deleting Gallery folders. - Messaging: Added export messages feature to HTML, SYLK, DIFF, RTF, XML, DBF etc. | |
06-07-2005, 06:13 | #3 (permalink) |
Junior Member Join Date: Apr 2005 Age: 42
Member: 134078 Status: Offline Thanks Meter: 0 | If the Release Note says it can support the Nokia 6680 then it should. Plus keep in mind it'll only work with IR or Bluetooth no cable supoprt. What i did was i had the same problem you had, i just changed the year of my date to 2004 and BAM it worked : ) i'm now transferring all my data to the comp.. |
Oxygen Phone Manager v 2.4 for symbian and Mobimb v3.41 | yanalalhasan | Nokia Multimedia | 16 | 10-17-2007 15:33 |
Oxygen Phone Manager Symbian 2.12.0.30 | cordell | Nokia Multimedia | 4 | 03-17-2007 12:47 |
Download Oxygen Phone Manager II 2.4.0.1 Retail English Version | mahdialawneh | Nokia Multimedia | 1 | 07-31-2004 04:17 |
