Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
04-09-2005, 08:42 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Age: 34
Member: 112302 Status: Offline Thanks Meter: 28 | SPEED OF NOKIA 6600,7610 AND OTHER S60 DEVICES IS VERY SLOW. ITS A BIG PROBLEM....... HERE IS SOLUTION... ------------------------------------------------------------------------- Speed up your 6600 First go to ur To-do List (default app of ur N6600) - Make a note and input as follows Subject: Speed Due Date: 01-29-2005(mm-dd-yy) Priority: set to High then press Done - Make a second Note and input as follows Subject: Qoukie Due Date: 01-29-2005(mm-dd-yy) Priority: set to Low then press Done - Do not exit yet, Press the Option of your Subject note w/c is Speed and Mark as done - then Press the Option of your Subject note w/c is Qoukie and Mark as done - Now, reboot ur mobile. If you can notice any difference about the speed, pls post results here.. Works fine with my N6600. can anybody try this with other S60 phone?? and see the difference.. |
04-09-2005, 08:49 | #3 (permalink) |
Member: 112302 Status: Offline Thanks Meter: 28 | HI GUYS, DO U KNOW THAT "TOTAL irRemote" by pisolic is very big problem.... it dosent register with keygen.... so, i fownd a new irremote by novii its free and better then ir remote and its range is more then irremote by pisolic. U CAN DOWNLOAD IT FROM THE THREAD POSTED BY atin_garg2005. THREAD NAME IS " Nokia S60 6600 APPS,KEYGENS ETC... " |
04-10-2005, 18:22 | #4 (permalink) |
No Life Poster Join Date: Feb 2005 Location: new delhi, india Age: 39
Member: 120647 Status: Offline Thanks Meter: 32 | hey atin ur solution to s60 speed workd but it caused serious problems, it effects the display of the phone so apps or themes requring high display fails to load, even the thumbnail preview in gallery is ditorted. please tell me if there is any way way to rollback the procedure. or anyone please tell me the code 4 original settings under the settings menu. |
01-14-2007, 22:07 | #5 (permalink) | |
Junior Member Join Date: Dec 2006
Member: 416913 Status: Offline Thanks Meter: 0 | Quote:
this is a really important trick but about the date do we put the same date u posted or the date for a long time to come to it work till that date ?!!! | |
01-17-2007, 18:03 | #8 (permalink) | |
Freak Poster Join Date: Feb 2006 Location: India
Member: 237210 Status: Offline Thanks Meter: 90 | Quote:
so 1st check bt module by inputting *#2820# with sim inside. if bt id is shown then try software, otherwise just replace bluetooth module and flash to the latest version | |
05-06-2007, 21:20 | #9 (permalink) | |
Freak Poster Join Date: Dec 2003 Age: 38
Member: 46173 Status: Offline Thanks Meter: 1 | Quote:
Thanks.... it worked My 6600 is working about 75% faster. | |
All Motorola Problems And Solutions Post Here.... | Gulshan_80 | Motorola Hardware Repair | 315 | 04-15-2014 20:07 |
Sing In problem and solution | salmanafzal | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 12-16-2009 02:29 |
K800i EAR PIECE PROBLEM NO SOLUTION IN FORUM | maplegsm | Sony Ericsson Hardware Repair | 0 | 07-31-2008 14:13 |
i have some problem with soft for series 60 3rd. Anybody can help me | zicusa | Nokia Multimedia | 0 | 10-17-2006 13:04 |
a50 unlocking problems and solutions | jozob | x1x to x45/x50 | 2 | 01-08-2003 18:58 |
