Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
![]() | #331 (permalink) | |
Junior Member Join Date: Apr 2008
Member: 750895 Status: Offline Thanks Meter: 0 | can u help me,bro? Quote:
![]() | #332 (permalink) | |
Member: 750895 Status: Offline Thanks Meter: 0 | hi Quote:
![]() | #333 (permalink) | |
Junior Member ![]() ![]() Join Date: Jun 2004 Age: 52
Member: 68374 Status: Offline Thanks Meter: 2 | Quote:
![]() | #335 (permalink) |
Member: 747351 Status: Offline Thanks Meter: 0 | Hi can you sign RotateMe2.0 Nokia N95 8GB IMEI: 352061022757690 Country: The Netherlands Email: [email protected] Thanks in advance! |
![]() | #336 (permalink) |
Junior Member Join Date: Feb 2007
Member: 453077 Status: Offline Thanks Meter: 1 | Hi, Can you please sign route66 for n95 for me? 356962018206392 Thanks very much, [email protected] http://rs165gc2.rapidshare.com/files.../r66_73545.rar |
![]() | #337 (permalink) |
Member: 751327 Status: Offline Thanks Meter: 0 | Model: Nokia N95 imei #:359542012655971 country: Australia email:[email protected] Thank you VERY much! ![]() |
![]() | #338 (permalink) | |
![]() | #339 (permalink) | |
![]() | #340 (permalink) |
Member: 68374 Status: Offline Thanks Meter: 2 | i cant help you now....try to hack your phone by our self... follow this tutorial... A simplified tutorial on how to mod/hack your firmware. Cedits go to FCA00000, leftup & others for this brilliant hack Kindly note its essential that you hack your firmware for the first time using the computer. Also active python does not work on Windows vista well atleast the version that i have so XP is the way to go about it. credits to keshav. You will need certain softwares and a PC: 1. Download and Install ActivePython on your PC 2. Download and Install PySerial 3. The magic python script and TRK application a.) for Nokia (n95 ,n82 ,etc.) + AppTRK / (for n73, n80 etc) + AppTRK (Thanks to FCA00000) b.) for UIQ based (P1i , w960i etc.) (Thanks to swmail) 4. Application to turn security on and off (from phone) a.) for Nokia (n95 ,n82 ,n73 ,n80 etc.) (Thanks to FCA00000) b.) for UIQ based (P1i , w960i etc.) (Thanks to swmail) The Real Part: 1. Install the AppTRK application on your phone's memory and start it, then in options>settings, select connection as USB. 2. Connect your phone to your PC via USB in PC Suite mode and then AppTRK will report connected on your phone 3. Go to Control Panel>System>Hardware>Device Manager>Ports OR in Windows Vista: Control Panel>System>Device Manager>Ports. Note the COM Port your phone is using 4. Open the python script in notepad (the one downloaded in step 3 with .py extension) 5. Search "serial.serial" without quotes and then replace the numerical value in bracket with the value of your COM Port minus 1 i.e. if your port was 22 then replace it with 21. 6. Save the file 7. Run the script by simply double clicking it 8. Now if you see something like !!!!!!candidate!!!!!!! in the output window, or if you just saw the dos window and a few lines saying installing or sending etc, then..... congratulations now your phone is really yours!! 9. Now you can exit the AppTRK application. 10. Verify the hack with X-Plore, see if you can explore c:/sys/ 11. Now if you will reboot the phone you will have to reactivate the hack with above procedure OR to do it without PC do the following(Note: for the first time PC hack is needed) 12.a.) For Nokia : I. copy CProfDriver_SISX.ldd from RAR downloaded in step 4a into C:\sys\bin II. install CapsOn.sisx III. install CapsOff.sisx b.) For UIQ based I. Copy patched trkdriver.ldd from rar downloaded in step 4b to c:\sys\bin\ II. Install CapsSwitch on your phone 13. Now you can switch security on and off without pc through these applications CapsOff = Security OFF and do whatever you want to do with your phone CapsOn = Restrictions ON After this hack you'll be able to install unsigned applications without SymbianSigned Note: This tutorial is same for all symbian OS 9 phones(n95,n82,n73,n8,P1i,w960i etc.) until'n'unless mentioned So here's the HOWTO for installing unsigned applications on your Symbian phone after you have hacked it(CapsOFF) :- 1. Download this rar file containing the certificate, the key and the authentication file for your phone. (Thanks to leftup of symbian freak) 2. Copy the file "00000001" to "C:\resource\swicertstore\dat\" on your phone and mark the file read-only from X-Plore or other similar file explorer. If the given directories do not exist , create them 3. So now your own authentication system is installed on your phone. Now you need to sign your sis files with the given certificate and key in the rar file. 4. For signing sis files (pc based method)(works for all Symbian OS 9 phones) I) Download and install SignSis GUI on your PC II) Select the given certificate and key(password is blank) given in 'the rar file you downloaded' III) Select the file you need to sign and sign it and transfer it to your phone, install normally IV) Now you have the application installed with all its capabilities ------------------------------OR--------------------------------- 4. Mobile based method(no need for a pc), works only for Nokia phones I) Download and install MobileSigner on your phone II) Open MobileSigner and select and sign the 'unsigned sis file' and MobileSigner will generate a signed sisx file in the same directory as the source file. III) Install the generated sisx file and application will be having all its capabilities. This is the simplest and easiest way and it worked for me in one shot. Enjoy http://www.ipmart-forum.com |
sign application failuar | pixel | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 03-29-2010 14:33 |
No More Signed Applications !!!!! | umeshmaslekar | Nokia Multimedia | 99 | 03-01-2008 12:33 |
Request for signed application | justice_pk | Nokia Multimedia | 0 | 09-03-2007 08:29 |
Signing Applications.. | dancingdaniel | Nokia Multimedia | 5 | 07-25-2007 14:49 |
F-Secure detects spyware in Symbian signed applications? | apocalypso | Nokia Multimedia | 0 | 05-16-2007 06:37 |
