Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
02-13-2007, 11:22 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: InCrEdIbLe InDiA
Member: 242626 Status: Offline Thanks Meter: 218 | ...:::Symbian OS 9.1 Applications...::: |
The Following 5 Users Say Thank You to BURHANLAHERI For This Useful Post: |
02-13-2007, 11:37 | #3 (permalink) |
Member: 242626 Status: Offline Thanks Meter: 218 | ScreenShot v2.1 S60 Symbian OS9.1 for 3d s60 devices ScreenShot v2.1 S60 Symbian OS9.1 for 3d s60 devices |
The Following 10 Users Say Thank You to BURHANLAHERI For This Useful Post: |
02-13-2007, 11:43 | #4 (permalink) |
Registered User Join Date: Jun 2005 Age: 42
Member: 153229 Status: Offline Thanks Meter: 28 | Do u have a full working version of any call recorder without beep for Nokia N73 which is Symbian OS v9.1 series 60v3? I have searched the entire forum but didn't find any one. I also need an anti-theft software for the same mobile. I have found trial versions of the same but couldn't find the full versions. So please post it here if u have them. |
The Following 3 Users Say Thank You to amrutbairy For This Useful Post: |
02-13-2007, 11:49 | #5 (permalink) |
Member: 242626 Status: Offline Thanks Meter: 218 | ScanR Uploader v1.0 for Symbian S60 V3 ScanR turns your Symbian camera phone into a scanner, copier and fax. Scan business cards, fax documents and capture whiteboard notes. Size: 288.74 Kb Compatible with: Other Symbian devices :: Series 60 v3 |
The Following 8 Users Say Thank You to BURHANLAHERI For This Useful Post: |
02-13-2007, 12:08 | #6 (permalink) | |
Member: 242626 Status: Offline Thanks Meter: 218 | Quote:
Killer Mobile Total Recall.v1.0.S60v3.SymbianOS9.1.Cracked-SyMPDA Killer Mobile Total Recall.v1.0.S60v3.SymbianOS9.1.Cracked-SyMPDA -Record in AMR or WAV format -Unlimited recording length -Record to the internal memory or external memory card -Intuitively named clips **Register with 0 or any key** | |
The Following 13 Users Say Thank You to BURHANLAHERI For This Useful Post: |
02-13-2007, 12:11 | #7 (permalink) |
Member: 153229 Status: Offline Thanks Meter: 28 | I have this but i want one which does not beep while recording. And also if possible it should be a full version which records for unlimited time i.e. till the memory gets over. Is it available with u???? |
The Following 4 Users Say Thank You to amrutbairy For This Useful Post: |
02-13-2007, 12:23 | #8 (permalink) | |
Freak Poster Join Date: Oct 2006 Age: 35
Member: 371683 Status: Offline Thanks Meter: 48 | Here You Are Quote:
Dear amrutbairy, I searched a lot and found something very usefull for you. CLICK THANKS IF YOU LIKE MY POST 1)Smartphoneware.Best.CallRecorder.v1.01.S60v3.Symbi a nOS9.1.incl.Keygen This is a fully customisable call recording application with rules for saving conversations for incoming/outgoing calls from known/unknown numbers. Easy to use and extremely discrete. How to start: 1. Activate Best CallRecorder - for this select Settings command from menu, then toggle the Activate option to On state. 2. To have Best CallRecorder saving only those phone conversations you need, select Rules command from menu and set the rules according to your requirements; The main view of Best CallRecorder shows all phone conversation records. Here you can listen to those records, delete them and get detailed information about a record. The list of operations with records is following: * Play record. While playing a record, you can change the volume with joystick left/right moves; * Call a contact or a phone number. If the highlighted record has a phone number associated, you can dial it even without exiting Best CallRecorder - just press the Call button or select this command; * Properties - displays a dialog with detailed information about the record; * Delete (hot key: 'C') - deletes the marked records; * Delete all; * Pack - deletes all records from the list which don't have a sound file associated (e.g. if it was manually deleted); * Refresh - reloads the list of records; Best CallRecorder allows creating the rules of following types: * Default - this rule will be put into action if none of the active rules is used; * Unknown - if caller's number cannot be defined this rule will be used; * Contact - you can set a separate rule for a specific contact; * Group - a rule for a group of contacts; * Phone - a rule for a phone number. You can use a mask for phone numbers. A match pattern can contain wildcard characters "*" and "?", where "*" matches zero or more consecutive occurrences of any character and "?" matches a single occurrence of any character. Example: '*111' - all numbers ending at 111; '111*' - all numbers beginning with 111; '12?34' - all numbers like 12034, 12134 ... 12934; Each rule can have the following actions set to perform when the rule is matched: * Ask before record - if this action is selected, Best CallRecorder will ask you whether to record a phone call or not; * Record incoming calls - allows recording incoming calls; * Record outgoing calls - allows recording outgoing calls; Note: If you haven't chosen any action or have chosen only Ask before record, this rule will be disabled. Compatible devices: Nokia 3250, Nokia 5500 Sport, Nokia E50, Nokia E60, Nokia E61, Nokia E70, Nokia N71, Nokia N73, Nokia N80, Nokia N91, Nokia N92, Nokia N93 Download Link:http://www.sendspace.com/file/041iwp | |
The Following 25 Users Say Thank You to ankit_jain For This Useful Post: |
02-13-2007, 12:35 | #10 (permalink) |
Member: 371683 Status: Offline Thanks Meter: 48 | 2)Ultimate voice recorder(Beep Off)Cracked. Install both files UltimatePortable.Ultimate.Voice.Recorder.v3.01.S60 v3.SymbianOS9.1.Incl.Keygen.Patch-BiNPDA.sis UltimateVoiceRecorder v3_01_1.sis DOWNLOAD:http://d.turboupload.com/d/1523055/u...luded.rar.html |
The Following 8 Users Say Thank You to ankit_jain For This Useful Post: |
02-13-2007, 12:41 | #12 (permalink) |
Member: 242626 Status: Offline Thanks Meter: 218 | Softtrends.Software.LivePVR.v2.62.S60v3.SymbianOS9 .1.Cracked-SyMPDA Softtrends.Software.LivePVR.v2.62.S60v3.SymbianOS9 .1.Cracked-SyMPDA No beep Phone Conversation Recording, Meeting notes recording or Voice recording / playback in WAV and AMR format. LivePVR, is a true mobile application that provides 3 extremely useful Personal Voice Recorder functionality; Meeting Notes PVR, Phone Call PVR and Voice Recorder PVR. Meeting Notes PVR. Meeting Notes PVR Meeting Notes PVR is the personal voice recorder mobile application that provides real time meeting notes using Timed or Manual capture modes. It allows the user to record moments-in-time, or "thoughts" during a meeting, but without missing the context that led up to that main point or thought. Using pre-defined application settings, a certain number of seconds are recorded using the Rolling Buffer, both before and after pressing the Timed Capture. This ensures the user always have proper context to the recordings. For example, you are in a meeting with LivePVR on and you have set the pre-defined value to 45 seconds. Suddenly you realize that you will need to record this part of the conversation. When you press the button, LivePVR will record the conversation to a file starting from 45 seconds before you pressed the button till either you press the stop button (if you have selected manual capture) or the time pre-set by you (if you are using timed capture). Phone Call PVR Phone call PVR is the personal voice recorder mobile application that provides real time phone call recording using Automatic or Manual capture modes. It allows the user to record mobile phone conversations, either by recording all phone calls automatically, or by recording the next call the user makes Voice Recorder Voice PVR is the personal voice recorder mobile application that provides voice recorder functionality, without the limits on how long the user can record. As long as the user has storage, such as an SD Card in the phone, user can record whatever the user likes, for as long as the user likes Compatible Devices Nokia 3250 (S60 3rd Edition) Nokia 5500d (S60 3rd Edition) Nokia E50 (S60 3rd Edition) Nokia E60 (S60 3rd Edition) Nokia E61(S60 3rd Edition) Nokia E62 (S60 3rd Edition) Nokia E70 (S60 3rd Edition) Nokia N71 (S60 3rd Edition) Nokia N73 (S60 3rd Edition) Nokia N75 (S60 Erd Edition) Nokia N80 (S60 3rd Edition) Nokia N80 IE (S60 3rd Edition) Nokia N91 (S60 3rd Edition) Nokia N91 8Gb (S60 3rd Ed.) Nokia N92 (S60 3rd Edition) Nokia N93 (S60 3rd Edition) Nokia N95 (S60 3rd Edition) work's with out beep while recording |
02-14-2007, 09:21 | #13 (permalink) |
Member: 242626 Status: Offline Thanks Meter: 218 | Contacts Transfer version 3.01 for S60 9.1 3rd Contacts Transfer version 3.01 for S60 9.1 3rd Have you ever tried to copy the contacts database from one S60 based phone to another? Perhaps using a PC suite or SyncML? Perhaps you have noticed that something was missing in the end? No problem, with the Contacts Transfer application you can copy the entire contents of the contacts database includig thumbnail images and caller groups from one phone to another via bluetooth, infra-red or a memory card. |
02-14-2007, 20:23 | #14 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Kuala Lumpur Age: 43
Member: 287805 Status: Offline Thanks Meter: 132 | ok i will help u burhanlehari to post my collection of 3rd edition software/apps here......... download it guys and plz rate this tread for burhanlehari......... Best Taskman helps you better control your device. It shows full information about device memory, running applications, processes, opened files and installed applications. The software allows extended task management, memory control and much more functions to explore. http://rapidshare.com/files/15869407/Best_...l_teamcrack.rar Best Crypto Protect your private photos, voice and sound files, videos, confidential documents - just any kind of files on your smartphone! Every smartphone user stores sensitive data on his device. It could be private photos, confidential voice notes, business documents, etc. You don't want an unauthorized person to get access to your confidential or private data, do you? Protect your confidential and private data with Best Crypto now! http://rapidshare.com/files/15870499/best_...l_teamcrack.rar HandyZip v1.02 Handy Zip program for Nokia N71, Nokia N73, Nokia N80 is necessary for all people who receive messages via e-mail on the smartphone. With Handy Zip Nokia N71, Nokia N73, Nokia N80 software installed on your phone, you can easily open a zipped attachment directly from Messaging application and view/modify the files inside it. Without this application for Nokia N71, Nokia N73, Nokia N80 you can't check what is inside .zip archive you received with the message. Just imagine what will happen if important document is not read in time. COMPATIBLE FOR N71, N73, N80, N91 & 3250. SERIAL NUMBER : 57887362-40297778 http://rapidshare.com/files/15871172/Handy...l_teamcrack.rar Y Browser you can access to your folders. Its not so good as FExplorer but sice FExplorer is not ported to 3rd edition yet its a really good alternative. http://rapidshare.com/files/15871674/Y_Bro...l_teamcrack.rar PASSWORDS : uncell@3rdEdition |
The Following 6 Users Say Thank You to uncell For This Useful Post: |
02-14-2007, 20:27 | #15 (permalink) |
Member: 287805 Status: Offline Thanks Meter: 132 | another apps 3rd edition for u all here............enjoy it kay from my collection Handy Key Lock Lock your Nokia N71, Nokia N73, Nokia N80 keys when you don’t use it. Set the timeout once and your smartphone will be automatically locked and protected against accidental pressing. SERIAL NUMBER : 57873730-39888946 http://rapidshare.com/files/15965015/Handy...l_teamcrack.rar System Explorer ysExplorer is yet another file and system explorer for the Symbian OS platform. Developing this may look weird as some other excellent - sometimes free - alternatives already exist on the market. However, none of those alternatives meet all of our requirements so we decided to go with our own solution. Support devices : 3250, N71, N73, N80, N91, N92, N93. http://rapidshare.com/files/15965196/SysEx...l_teamcrack.rar Psiloc Extended Recorder v1.10 Extended Recorder is a tool that overcomes 60 seconds limit imposed in Nokia phones and allows recording really long voice notes. It also registers incoming and outgoing calls.You will be able to record company meetings, important business negotiations and phone calls. compatible devices: Nokia 3250, E60, E61, E70, N71, N73, N80, N91 or N93 . http://rapidshare.com/files/15965323/Psilo...l_teamcrack.rar NTorch Lite Built upon the success of N70Torch, NTorch Lite for S60 3rd Edition is the most innovative application designed for Nokia N80, N71 and N73, allowing their built-in Flash to be used for illumination. Now with reduced light beam, your flash can be turned on for a much longer period of time, while avoiding excessive heat being generated by the LED. Best of all, NTorch Lite can send out Visual Distress Signals that might one day save your life! ACTIVATION CODE : 28601 http://rapidshare.com/files/15965458/NTorc...l_teamcrack.rar If the ACTIVATION CODE not working,u all can download this apps..... http://rapidshare.com/files/15965531/Spot_...l_teamcrack.rar PASSWORDS : uncell@3rdEdition |
How to hackFor Symbian OS 9.1 devices and For Symbian OS 9.2 devices (Step By Step) w | hoaithuc | Nokia Multimedia | 3 | 10-09-2009 00:45 |
Symbian OS 9.1/9.2 Folder System [well explained] | Afzaal | Nokia Multimedia | 3 | 12-10-2008 13:00 |
tv-out sis need for sis60,OS-9.1/9.2 | jignesh_1000 | Nokia Multimedia | 1 | 02-13-2008 08:08 |
