gx 15 dead FULL FLASH PROCEDURE.............. MY GX 15 IS DEAD AND I HAVE READ ON THE FORUM THAT WE SHLD FLASH THIS PHONE WITHOUT BATT BUT IT ASKS FOR DRIVERS PLZZZZ SOME BODY GIVE ME THOSE DRIVERS AND I NEED A TOOL TO UPGRADE THIS PHONE AND COMPLETE FLASH FILE FOR GX 15 PLS SOMEONE TELL ME THE COMPLETE PROCEDURE TO REVIVE THIS PHONE:confused: :confused: :confused: :confused: :confused: |
Have you installed the GX15 Upgraditng tool? It has the drivers in it... Here you are ;) (Just remove the .txt extension) |
got drivers thanks for it but what abt complete procedure bec thats very inp it will be my first time i m flashing a sharp ph plzzzz co operate me |
i have one gx15 whene i flash it with select (file sys init) option after flashing it say me eror and fone not power on .but if i flash it without select (file sys init )option it flash corectly & give me checsum corectly but phone not power on too. any solution for this case |
i m confused what is to be selected in PROGRAM and in FILE SYSTEM:confused: IN THE SHARP UPGRADING TOOL |
gx15 flashing procedure Quote:
remove battery from phone then connect using nec 3g usb unlock cable allow pc to load drives ten un gx15 flashing tool, if correctly installed one of the com ports on the sw will be highlighted, now select file to flash to phone and allow sw to do its job (takes approx 15 mins) mad4 |
There Are 3 Colums 1) Program 2) File System 3)diag I Have Complete Flash File Of 11.7mb Now In Which Colum Should I Sel This File Thanks For Fast Cooperation THESE 3 COLUMS R IN SHARP UP TOOL |
Filesystem = Your files & configuration. Diag = Only can extract it, its the binary code of the diag menu. Firms&filesystems are in .mot extension, you can extract it.. If you want to upload to your phone a new firmware (using an official firmware) you must do the following: Go to the folder where you installed The GX15 Upgrading Tool ( c:\program files\The GX15 Updrading Tool ) and open a file called flash.ini (the file is hidden, you must have in windows activated the option to show hidden files) Find in flash.ini a line containing INITIALIZE_MODE = 0x01 Change it with INITIALIZE_MODE = 0x00 Save the file Now open The GX15 Upgrading Tool, you will see less options in the program, now you can flash original sharp firmwares into your phone. If you want to upload&download extracted firmwares from other phones (not official firmwares) see http://forum.gsmhosting.com/vbb/showthread.php?t=229714 look at http://sharp.hacked.in , i recommend you to try the firmware A02-007-0243-GX15-HACK_NEUTRINO-[full_games] (you will be very surprised) (use official flash format to flash it => INITIALIZE_MODE = 0x00) |
