01-14-2006, 11:34 | #1 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Europe Age: 46
Member: 10946 Status: Offline Thanks Meter: 15 | GX-17 Drivers for flash don't work i want to flash a gx-17 and i have a nec 3g cable and i downloaded the drivers posted on this forum. When i connect the gx-17 without battery the computer asks for drivers and i put the drivers downloaded. I starts to install the drivers but it then shows "There was a problem installing this hardware USB DEVICE. Ann error occured during the installation of this device A service installation section in this INF is in invalid. What could be the problem? Thanks a lot |
01-14-2006, 21:07 | #3 (permalink) |
Junior Member Join Date: Jan 2006
Member: 215790 Status: Offline Thanks Meter: 0 | i had your same problem but i fixed it this way: -download and install the sharp gx15 upgrading tool -then connect the usb to the phone and select "authomatic" search for the drivers it will install the working drivers and you'll be able to flash your phone!!! byez |
01-17-2006, 18:55 | #5 (permalink) | |
Freak Poster Join Date: Jun 2005 Location: IN side of your thinking
Member: 152429 Status: Offline Sonork: 100.1580540 Thanks Meter: 19 | Quote:
01-17-2006, 23:36 | #6 (permalink) |
No Life Poster Join Date: Jul 2003 Location: Thessaloniki,Hellas Age: 44
Member: 33547 Status: Offline Thanks Meter: 17 | sdimitris i had the same problem. I think windows cannot copy the drivers to system folders by itself. copy the files to /windows/system32 and /windows/system32/drivers then reinstall the driver again It will work for sure There was a problem in the *.inf file which cannot allow to be copied correctly to the system folders by windows. try it |
01-31-2006, 20:39 | #8 (permalink) |
No Life Poster Join Date: Aug 2005 Age: 47
Member: 175544 Status: Offline Thanks Meter: 198 | www.unlockeasy.com.......................... |
05-17-2006, 02:55 | #9 (permalink) | |
Insane Poster Join Date: Dec 2003 Age: 49
Member: 45975 Status: Offline Thanks Meter: 4 | Quote:
for me works ok (installling in windows/system32/drivers/flsusb) thanks a lot | |
sharp gx 17 driver instalation problem | sameed_j | Sharp | 4 | 11-24-2009 03:49 |
gx 17 driver | ogiuwa | Sharp | 2 | 04-10-2009 09:49 |
please give me the procedure to connect gx 17 to accept flash | sofiame2006 | Sharp | 4 | 10-23-2006 23:40 |
Sharp GX-17 flasher for via chipset | Bakl | Sharp | 3 | 10-19-2006 12:16 |
need driver for flashing gx 25 | alarmtech | Sharp | 1 | 05-10-2006 11:34 |
