12-08-2005, 11:59 | #1 (permalink) |
Crazy Poster Join Date: May 2005
Member: 147907 Status: Offline Thanks Meter: 9 | GX15 Upgrading Tool error |
12-08-2005, 13:05 | #2 (permalink) |
Insane Poster Join Date: Aug 2005 Age: 44
Member: 175119 Status: Offline Thanks Meter: 1 | Go to the folder where is installed gx15 upgrading tool, open a fille called flash.ini, find in that file the following line INITIALIZE_MODE = 0x00 and change it for INITIALIZE_MODE = 0x01 save flash.ini and run the program.. now you see more options, now you can extract the firmware of your phone and flash it with extracted firmwares from your phone. The firmware that you have is the ferrari version firmware extracted from a GX25. If you have a gx15.. dont try to flash with a gx25 firmware, it will dont work.. If you have a gx25 you are using the wrong flasher, you must use the gx25 flasher made by platijet: ************.com/forum/showthread.php?t=11200 |
12-08-2005, 13:26 | #3 (permalink) | |
Member: 175119 Status: Offline Thanks Meter: 1 | Quote:
************* = m o b i l e - f i l e s . c o m | |
sharp gx15 dead even flashed with gx15 uppgrading tool | bismed | Sharp | 4 | 11-03-2009 15:12 |
Cannot Upgrade UFS....Upgrade Tool says my box is BLACKLISTED?!?!?!?! | KingKronik | UFS2 + UFS3-Tornadoflasher | 4 | 09-09-2008 23:54 |
MDA compact error 150:rom upgrade utility error | DARIFBS | HTC & PDA WM( With Touchscreen) | 0 | 09-12-2007 19:49 |
GX17,GX15 .... 0x04, 0x02 Error .... | VasiliuS | Sharp | 10 | 03-24-2007 13:49 |
"Privileged instruction" error while using the SCDR II upgrade tool on XP???? | ReyTech | SagMaster Team OLD Products | 4 | 08-28-2005 20:13 |
