08-04-2005, 16:00 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Midlands, UK
Member: 57937 Status: Offline Thanks Meter: 34 | GX25 Freezing on Start up got a GX25 that Freezes on Start Up and just displays VODAFONE HOW ARE YOU! and goes no further. Press buttons and it beeps, Displays insert sim on out side screen. Flashed the phone and still the same. Connected the handset, for the unlock proceedure, so as to reset the phone, but won't go into the **** mode. Anyone have any ideas on this problem |
11-22-2005, 22:49 | #5 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Athens - Greece
Member: 59935 Status: Offline Thanks Meter: 131 | I have this prob months ago. Till now can't solve it. After changing the cristall , sometimes phone works for litle time ... but in next try ..... phone freeze again .... If somewone can help .... BR |
11-22-2005, 23:02 | #6 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Greece Age: 47
Member: 26279 Status: Offline Thanks Meter: 274 | does the phone comunicate with SPST??if yes then: 1.connect with SPST and make data backup from another good gx25. 2.connect phone with problem and restore backup data from the goodone. program will say(a hiden window,thats why watch carefully taskbar) that imei is not the same and if you want to continue.then continue and thats it. if SPST gives error: "invalid machine" then this means that diag area has been formated and you can't connect it. did anyone tryed with my flasher???does my flasher gives a error code?? |
11-22-2005, 23:21 | #7 (permalink) |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Flashed with all FW - N.G. will try to repair Diags Area ... Nothing help phone dead !!! Last edited by NoName®; 11-23-2005 at 01:08. |
11-23-2005, 08:18 | #8 (permalink) | |
Member: 59935 Status: Offline Thanks Meter: 131 | Quote:
Still freezing ! I was try with different flash files (ferrari too) ..... Only i'm shure that the problem is in "main" PCB (with keyboard) ! BR | |
11-23-2005, 08:42 | #9 (permalink) |
Freak Poster Join Date: Jun 2004 Location: Greece, Veroia Age: 45
Member: 68628 Status: Offline Thanks Meter: 7 | I had one of those too... I rehot it and i flashed but the problem still existed... The phone after flashing it the first time was working (for a while) but when i turned it on again had just freezed again on booting. If i find something i will post results. BR |
11-23-2005, 10:32 | #10 (permalink) |
Member: 26279 Status: Offline Thanks Meter: 274 | you have 2 be shure that all phone is freezing(can make calls etc) and not only the display(happens to me also). try also: 1.on my flasher select "initialize" on file system area and press "start loading flash" 2.put phone to diag mode(BUT FIRST TRY SOLUTION WITH SPST) format user area and then diag area. |
11-24-2005, 00:45 | #15 (permalink) |
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | @platijet But in SPST only COM1/COM2 avaiable , when I try to use other SPST versions COM connection works good but when select USB - program searching for WUIBU KEY :-( |
E700 freeze on start up logo:the sollution | Platijet | Samsung Hardware Repair | 24 | 04-24-2006 15:18 |
SAMSUNG D500 freeze on start up with D500 logo and restart same... | gsm_unlock | SWIFT Platform | 25 | 11-03-2005 13:01 |
e100 freeze on start up, please urgent solution | florinmar | Samsung Hardware Repair | 0 | 07-20-2005 19:20 |
e700 freezes on start-up? | gmx | SYSOL Platform | 4 | 05-17-2005 17:47 |
P800 , Freeze on start-up animation !!! | VsH-GsM | Sony Ericsson | 40 | 04-15-2004 16:32 |
