03-25-2007, 10:36 | #32 (permalink) |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | don't spam the board with FOOLISHNESS the 17 flasher do not work that fuc..rs that say work wasted my time on the forum........ok for the last time flasher do not work maybe they have some nother problem and phone alive but the resason is not flasher |
04-19-2007, 09:54 | #35 (permalink) |
Freak Poster Join Date: Aug 2004 Location: spain Age: 46
Member: 79485 Status: Offline Thanks Meter: 47 | Oooooooooooooooohhhhhhhhhhhhhh Please!!!!!!!!!!!!!!!!!!!!!!! Gx17 Doesnīt Work On Gx29!!!!!!!!!! This Is A Waste Of Time!!!!!!!!!!!!!!!!!! U Canīt Flash Fully A Gx29 With Gx17 Flasher Of Platijet!!!!!! |
04-23-2007, 01:55 | #37 (permalink) |
Insane Poster Join Date: Dec 2005 Location: JAMAICAA Age: 39
Member: 204759 Status: Offline Thanks Meter: 1 | Gx 92 Cable I HAVE MOFIFIED MY CABLE TO MAKE CHRGE MY GX29 BUT WHEN I CONNECT IT TO COMPUTER IT IS CHARGEING AND I CAN SEE THE USB ICON THE DISPLAY BUT THE COMPUTER SAYS UNKNOW DIVICE I TRY TO INSTALL DRIVER BUT WITH NO LUCK WHEN I CONNECT THE PHONE WITH OUT BATTRIES IT SHOW AS A UNKNOWN DEVICE BUT GO OFF WHEN I TRY TO INSTALL DRIVERS WHAT MUST I DO , I HAVE DOWNLOAD THE DRIVERS FOR PHONE IN THIS SITE AND I HAVE DOWNLOAD MODEM DRIVERS BUT CAN T GET PASS UNKNOW DEVICE . HELP HELP |
04-23-2007, 01:56 | #38 (permalink) |
Member: 204759 Status: Offline Thanks Meter: 1 | Gx 29 Cable I HAVE MOFIFIED MY CABLE TO MAKE CHRGE MY GX29 BUT WHEN I CONNECT IT TO COMPUTER IT IS CHARGEING AND I CAN SEE THE USB ICON THE DISPLAY BUT THE COMPUTER SAYS UNKNOW DIVICE I TRY TO INSTALL DRIVER BUT WITH NO LUCK WHEN I CONNECT THE PHONE WITH OUT BATTRIES IT SHOW AS A UNKNOWN DEVICE BUT GO OFF WHEN I TRY TO INSTALL DRIVERS WHAT MUST I DO , I HAVE DOWNLOAD THE DRIVERS FOR PHONE IN THIS SITE AND I HAVE DOWNLOAD MODEM DRIVERS BUT CAN T GET PASS UNKNOW DEVICE . HELP HELP |
04-23-2007, 22:41 | #39 (permalink) |
Member: 204759 Status: Offline Thanks Meter: 1 | Gx 29 I HAVE FOUND THE SOLUTION I CONNECTED THE D- AND D+ ON THE USB CABLE USB BACK WAYS , NOW I HAVE CONNECT THE PHONE WITHOUT BATTRIES AND INSTALL FLASH DRIVERS |
07-10-2007, 23:53 | #41 (permalink) |
Major Poster Join Date: Jan 2005 Location: GSM Network Age: 43
Member: 104927 Status: Offline Thanks Meter: 60 | Solution to unlock Sharp GX29 Hello all I have unlocked a 200606 gx29 from vodafone spain with those files and with the next proedure. So, here we are: Software is the Albelektronik team gx17-gx29 flasher Full flash is here: gx29 and folow the specifications from the atached image. All of you, have to do is flash the phone, without batery, with the files selected, using a NEC E8 cable, just like the specifications from the image. Reply problems... |
The Following User Says Thank You to sokettro For This Useful Post: |
08-17-2007, 13:32 | #43 (permalink) | |
Member: 104927 Status: Offline Thanks Meter: 60 | Quote:
Try to flash your phone completly with the files posted above and might work. I flashed a gx17 200707 with a complete firmware from another gx17 made on 200702 and works. Check if you have the drivers corectly instaled and use the software from albelektronik, may be useful. After that, if you will have the same problem again, send me a ymsg, i will try to help you. | |
08-20-2007, 14:44 | #45 (permalink) |
Member: 104927 Status: Offline Thanks Meter: 60 | |
sharp gx29 flash ok not power on | Formingus | Sharp | 31 | 06-02-2014 19:16 |
sharp gx29 flash ok not power on | Formingus | Sharp | 1 | 02-20-2007 12:26 |
I am lookinf for GX29 flash + flasher !! | makroud | Sharp | 13 | 02-19-2007 14:16 |
Sharp Gx29 Flash Procedure | yoni93320 | Sharp | 11 | 02-08-2007 16:14 |
