06-11-2004, 17:39 | #1 (permalink) |
Insane Poster Join Date: Mar 2004 Location: ARZEW -ORAN- ALGERIA Age: 44
Member: 56641 Status: Offline Thanks Meter: 0 | gx30 for unlocking with server gt v1.191 for griffin PROBLEM Press and hold power button!!! OK Sending Boot... Reading ... Done e/400/command execution error; Server Computed CODE: Phone has to be with original simcard or test card type *325266*6371# press M Goto Settings/Security/Mep Locks Enter phone code usually 0000 Select lock and Enter the code what's the problem!!! please help |
06-11-2004, 17:54 | #2 (permalink) | |
Product Manager Join Date: Mar 2002 Location: On the Edge
Member: 10347 Status: Offline Thanks Meter: 14 | Quote:
Problem resolved Regards NADS | |
08-11-2004, 10:57 | #4 (permalink) |
No Life Poster Join Date: Mar 2000 Location: next to you ; ) Age: 54
Member: 1133 Status: Offline Thanks Meter: 38 | Hello all... What if the phone when powered up shows "Handset Code" and does not allow you to type *325266*6371# press M Also phone lock is not 0000.... Many thanks in advance. |
08-11-2004, 23:45 | #5 (permalink) |
Freak Poster Join Date: Apr 2004 Age: 50
Member: 63553 Status: Offline Thanks Meter: 22 | The unlock was done using wrong option as the code that should be shown to be able to get into the locks menu is *01763*6371# If the default handset code is not 0000 then you either need to find the handset code or use a clip that will put the phone into test mode and then use the handset reset option (1) and then unlock also |
08-13-2004, 02:37 | #7 (permalink) | |
Member: 1133 Status: Offline Thanks Meter: 38 | My options are limited Do not have clips and cannot go into testmode Any sw or AT commands that can put the phone into Testmode. Cos I really don't get many GX30's here. ATB Quote:
Nokia 6280 Unlock with BB5 King V1.02 | Ramzan | BB5KING | 0 | 11-13-2008 15:17 |
V3 dead when unlock with smart-moto v1.23 | llcoolr | Motorola P2k | 7 | 08-06-2006 20:40 |
problem on nec338 after unlocking with server!! | infogsm | FuriouS II | 16 | 02-04-2005 22:41 |
new sonyerikson unlock with server | mobx montenegro | Sony Ericsson | 3 | 10-18-2004 14:35 |
