help gx10 charge problem someone can help for gx10 charge problem the connector is ok an also the charger |
i've the some problem! |
give us more details 1 Attachment(s) when you plugin charger is not charging at all??if yes then see the bridges on the picture and check the green fuse R348.if charging but for short time or showing that is charging but not,then check/change Q305,IC302 and IC306. this solution work also for GX20 |
so if the phone is not charging at all i bridge from pin 8 to fuse and fron pin 1 to grnd is this right? |
yes but this is not fuse but coil. also you must becarefull because pin8 on service manual is the 1st from the left and pin 1 is the 2nd from the right. |
