01-29-2005, 15:08 | #3 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Greece Age: 47
Member: 26279 Status: Offline Thanks Meter: 274 | give us more details when you plugin charger is not charging at all??if yes then see the bridges on the picture and check the green fuse R348.if charging but for short time or showing that is charging but not,then check/change Q305,IC302 and IC306. this solution work also for GX20 |
01-30-2005, 13:53 | #4 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: In My Pub
Member: 307549 Status: Offline Thanks Meter: 188 | Quote:
so if the phone is not charging at all i bridge from pin 8 to fuse and fron pin 1 to grnd is this right? | |
01-30-2005, 21:00 | #5 (permalink) |
Member: 26279 Status: Offline Thanks Meter: 274 | yes but this is not fuse but coil. also you must becarefull because pin8 on service manual is the 1st from the left and pin 1 is the 2nd from the right. |
help cf62 charging problem | asliyucegsm | Siemens Hardware Repair Area | 0 | 07-24-2007 11:41 |
Help 6233 charge problem. | rirou | Nokia Hardware & Hardware Repair | 2 | 06-15-2007 13:54 |
help v300 charge problem | shachash | Motorola Hardware Repair | 13 | 02-27-2006 08:00 |
Please Help!X450 Charging problem "Paused by Tempratur" | KUBAT1 | Samsung Hardware Repair | 3 | 07-04-2005 18:55 |
Pls help.R310 charge problem help | .::AkhavanGSM::. | Sony Ericsson Hardware Repair | 0 | 10-24-2002 17:04 |
