09-13-2004, 03:27 | #1 (permalink) |
Junior Member Join Date: Aug 2004 Age: 48
Member: 77582 Status: Offline Thanks Meter: 0 | how to solve gx20 unlocking problem after 4 hours i mean 4 long hours.....i have a couple of solutions for you!!!! 1 to unlock it i uset a usb cable...the name is ma-8110p in fact this cable is viewed by the computer as a com port (number 11) in this case you must change the port from 11 to 1 or 2 from the control panel!! now you have a flash cable!!!!!! 2-i used the sharp unlocker 3.1 but i had broblems in connetcting....solved leaving the fone without simcard and turned on.... -3click un liberar gx20 and than connctar you will see the i mei address on left 4-pay attention here....click on aplicar seleccion now it will work for a while and than it will say to turn the fon on by pressing the red until you see -xxxx- to turn it on unclip the fone from the cable!!!!!!!!!! don't touch any button on v-i-l-a-n-i unlocker when you turned on the fone you will see xxxx but nothing happen... now connect again the fone (turned on with the xxxx on the display) to tha cable and press again aplicar selecion....wait until says ok..... now you have your gx 20 free!!!!! |
09-13-2004, 07:21 | #3 (permalink) | |
Product Manager Join Date: Feb 2003 Location: Your Exclusive Source
Member: 20645 Status: Offline Sonork: 100.1579175 Thanks Meter: 635 | Quote:
help how to solve local mode problem while unlocking | neeraj1st | BB5KING | 5 | 11-21-2008 11:00 |
How to solve 6600 4blinks problem | ALFbcn2000 | Federal One | 5 | 06-07-2005 01:54 |
how to solve "no charging" problem after using ccs erase on 3650? | Alinus | Griffin | 0 | 02-17-2004 04:06 |
How to solve the unlock blocked problem? | kingmobilephone | Panasonic | 6 | 08-18-2003 13:30 |
