01-18-2006, 11:18 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Murcia,Spain Age: 45
Member: 116918 Status: Offline Sonork: 100.1590386 Thanks Meter: 559 | New GX30i Flasher Questions 1. does anyone have language descriptions for the flash file on the evil-hackers link supplied in this forum i need to use a unbranded file with English and Spanish but am not sure which to use i have them all on my computer. 2.When reading the flash i read and saved the 4 different files. Program FileSystem BSRam Diag But it looks by the flash files i have there is only one file to write where should i write this to Program??? FileSystem??? BSRam??? Diag??? Thanks for any help you can give me and once again thanks so much to Platijet for this great flash prog..... |
01-18-2006, 16:48 | #2 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: Athens - Greece
Member: 59935 Status: Offline Thanks Meter: 131 | Quote:
Overwrite old one when prompted. BR | |
01-19-2006, 11:03 | #5 (permalink) |
Member: 116918 Status: Offline Sonork: 100.1590386 Thanks Meter: 559 | The above file is not excatlly what i need this seems to change the config of the software to the GX30 unlocker not the GX30i i know now that i need to write the flash to the program area of the handset as i have tried this with newer versions of the Vodafone firmware and the software works 100% so all i need now is a unbranded flash file to the best i can understand by what i have read is there is at current no GX30i unbranded firmware available and if there is it is well hidden but i have read that the GX32 Firmware is a unbranded version of the GX30i with English and Chinese language am i correct in this and if so if these any GX32 Firmware available as once again it seems not and if there is would it be possible to Flash a GX30i with this. I am more than happy to try this flash if someone has a file for me to test it with as i have backed up all the origanal flashes from my phone so a repair should be easy. |
01-19-2006, 20:00 | #6 (permalink) |
Major Poster Join Date: Jun 2005 Location: Germany Age: 44
Member: 155910 Status: Offline Thanks Meter: 1 | compatibel with original file "flash.ini"? This new GX30 flasher correctly works with an original file "flash.ini" from SPST? If to take an original file "flash.ini" from SPST for the new GX30-flasher, it is possible to choose "file system initialize" at flashing. It is necessary for choosing "file system initialize" for upgrading GX30 to GX30i? And many thanks for this program!!!!!!!! |
01-19-2006, 20:06 | #7 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Greece Age: 47
Member: 26279 Status: Offline Thanks Meter: 274 | why you you want to do all this??????read the 1st post how to convert gx30 to gx30i. http://forum.gsmhosting.com/vbb/showthread.php?t=264050 there is no reason to have many threads for same things.so we will continue there. thread closed |
Gx30i flasher and flash files | Unlocker AL | Sharp | 2 | 05-29-2007 08:39 |
Any New GX30i Firmware with Good Menus | rohitkpatil | Sharp | 0 | 05-18-2006 08:49 |
Redbox - 100% unlocking of new GX30i | yeldar | Redbox | 14 | 12-16-2004 22:39 |
Dejan Flasher question | cresta | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-13-2001 08:38 |
VPP, BTEMP - Flasher question | Ice Dragon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-14-2001 01:44 |
