11-22-2004, 15:41 | #1 (permalink) |
Junior Member Join Date: Nov 2004 Age: 43
Member: 93199 Status: Offline Thanks Meter: 0 | SHARP GX-15 questions I bought a GX-15 in Portugal (from Vodafone). And I can't upload to my mobile jar and/or jad files. How can I do it? And how can I erase the 'Live!' menu from it??? Please answer! Many thanks! |
11-25-2004, 13:37 | #3 (permalink) |
Junior Member Join Date: Sep 2004 Age: 40
Member: 84124 Status: Offline Thanks Meter: 0 | I think if the firmware is flashed it is possible to get rid of the vodafone s.h.i.t.t.y. menus I am trying with my GX15... Will put a small webpage saying how etc etc after I do it on: http://i.don-t.servebeer.com/sharpgx15 At the moment there are just the files present... I just hope it works |
11-25-2004, 17:16 | #7 (permalink) |
Junior Member Join Date: Nov 2004 Location: ****in´Hell
Member: 91978 Status: Offline Thanks Meter: 0 | FOR JAVA GAMES do this: Options-permiso-web access and selecct NO... no more connections to wap service for update or download games...muhahahahaha NO MORE LIVE BUTTON do this: Settings-Network-Wap settings (copy vodafone option)... and... ypou must change the following: Connection type-------gprs gprs settings---APN--type "unknow", name-------"unknow", password---"unknow" l ALL DONE MATE!!! |
11-26-2004, 08:19 | #8 (permalink) |
Member: 84124 Status: Offline Thanks Meter: 0 | I am almost sure that this flash file (A24-007-0213-GX15U.MOT) is vodafone-free. What is needed to flash this phone? I have the following items I am sharing. -Sharp Product Support Tool Software (v1.3) -The GX15 Upgrading tool -Flash file (A24-007-0213-GX15U.MOT) which I think is vodafone-crap free Can be downloaded from http://i.don-t.servebeer.com/sharpgx15 Of course a data cable is needed to flash the firmware. Now... I heard that a data charging cable (i.e. a data cable that charges the mobile at the same time) is needed to complete this operation. Is that cable necessary or is it possible to do it by a common USB Data Cable? Is there anyone who has succeded in flashing this mobile and knows something regarding the cable? Please contribute to this post if you can help. Regards, goci |
11-26-2004, 08:42 | #9 (permalink) |
Freak Poster Join Date: May 2004 Location: http://sharp.x-mc.net Age: 37
Member: 65953 Status: Offline Thanks Meter: 0 | I don't know if you need a charging cable. But if yes, no problem: You can modify a normal USB-cable to work as charging cable. Just connect pin 2 (data +) and pin 4 (charger +). I did this on my cable and now it charges when it's connect to the PC ;-) |
11-26-2004, 11:24 | #10 (permalink) | |
Member: 93199 Status: Offline Thanks Meter: 0 | Quote:
But after that how can i send games to phone Thanks | |
11-26-2004, 13:02 | #12 (permalink) | |
Insane Poster Join Date: Sep 2004 Age: 42
Member: 83208 Status: Offline Thanks Meter: 0 | Quote:
You need the Upgrading Tool, Data Cablea and of course the Flashfile. You don´t have to install the whole spst soft | |
11-29-2004, 09:03 | #13 (permalink) |
Member: 84124 Status: Offline Thanks Meter: 0 | Ok... we got the software to flash this thing... I still haven't got a clear illustration of the USB to GX15 data & charging cable connections... The cable should be able to transfer data and charge the mobile at the same time. Anyone has got a good illustration please? |
12-11-2004, 17:19 | #14 (permalink) |
Member: 84124 Status: Offline Thanks Meter: 0 | Finally I have managed to flash the phone with the following 3 firmwares: -A02-007-0185-GX15.MOT -A02-007-0186-GX15.MOT -A24-007-0213-GX15U.MOT ALL OF THESE 3 ARE VODAFONE FIRMWARES! (doh'!) To flash it, the following things are needed: -The GX15 Upgrading Tool -USB Data Cable with charging function -A .MOT Firmware File -And the servicing manual for instructions if needed How it is done? -Install The GX15 Upgrading Tool Software and the GX15 Upgrading Tool USB Driver for the USB data cable. -Switch off phone, remove battery and SIM Card -Connect it via USB -Run The Upgrading Tool and choose the location of the .MOT firmware file -Tick the Port used by the system for USB. Tick Program Download and File System Initialize. -Click Start Loading Flash For other technical info you may have a look at the Sharp GX15 Servicing Manual NOW... Anyone who finds flash files for this mobile other than the 3 mentioned above and posts their location will be greatly appreciated. -= gociii =- |
12-24-2004, 09:57 | #15 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Slovenia Age: 48
Member: 15385 Status: Offline Thanks Meter: 9 | USB drivers? Hi to all! I read a lot of threads about how to unlock Sharp gx25. I have USB cable, I have thia AllSharp program, but don't have drivers to instal USB cable for GX 15. Does anyone know where can I get those drivers or. how can I install it? Thanks in advance for any help. BR, Dejan |
Is it possible to unlock a sharp GX 15 without a CABLE | alexmart | Sharp | 6 | 01-02-2005 23:18 |
Sharp Gx 15 | Mansoor | Redbox | 9 | 12-24-2004 14:07 |
SHARP GX-15 questions | schy | Sharp | 3 | 11-09-2004 19:13 |
Sharp GX 15???????????? | .::Zafar Communication::. | FuriouS II | 2 | 09-03-2004 00:27 |
sharp gx 15 SOLUTION | zoudash | Sharp | 3 | 08-30-2004 16:37 |
