09-22-2005, 18:47 | #1 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 579 | Sharp gx 25 dead after unlock After format the phone does not power on No comunication after dead phone What can i do urgent Any procedure to flash or something else is new one Vodafone mobile |
09-22-2005, 19:39 | #3 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Greece Age: 47
Member: 26279 Status: Offline Thanks Meter: 274 | measure battery if voltage is ok (higher than 3,7 Volts) else use my flasher to revive your phone.: http://forum.gsmhosting.com/vbb/showthread.php?t=213607 |
09-22-2005, 19:52 | #4 (permalink) |
No Life Poster Join Date: Apr 2001 Location: AGADIR Morocco
Member: 3936 Status: Offline Thanks Meter: 237 | try this push 0 3 upper right buttom power key simultanously screen should blink lightly then type 0123 +upper R buttom this should activate diag mode then 99 etc etc regards |
09-23-2005, 09:03 | #7 (permalink) | |
Member: 3617 Status: Offline Thanks Meter: 579 | Quote:
09-23-2005, 11:05 | #8 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Mediteranean
Member: 59352 Status: Offline Thanks Meter: 50 | 0 3 top right .........NOT WORK with Gx25 ok???? it's working with old version so, for gx25 dead you need: 1- Cable nec with external power (as nec 616) 2- drivers usb gx15 3- flashers for gx25 and all be OKKKK i had the same problem |
09-23-2005, 11:07 | #9 (permalink) | |
Member: 26279 Status: Offline Thanks Meter: 274 | Quote:
DRIVERS IS NOT THA SAME..RIGHT DRIVERS INCLUDED ON FLASHER | |
09-23-2005, 15:09 | #10 (permalink) |
No Life Poster Join Date: Sep 2005 Location: London, UK
Member: 178513 Status: Offline Thanks Meter: 109 | www.albelektronik.com --------------------------------------------------------------------------------------------- For first time in the world Albelektronik TEAM ofer his big job, free for his *******r [ Albelektronik Sharp Gx25] with this software You can repair phone wich dead during unlock. Read end Write Flash and FS We keep it up! We keep promis! Albelektronik TEAM Products [ Project Started ] Together can do more! Last edited by Platijet; 09-23-2005 at 15:17. Reason: only english languange. |
09-23-2005, 15:41 | #11 (permalink) | |
realy??? do you know how many times i have seen my flasher with other name?? at least 7 times. every one can do this if edit the flash.ini file. | |
09-23-2005, 16:19 | #12 (permalink) | |
Freak Poster Join Date: Aug 2005
Member: 172227 Status: Offline Thanks Meter: 19 | Quote:
http://www.unlockeasy.com/modules.ph...ownload&cid=80 Last edited by Platijet; 09-23-2005 at 16:22. Reason: only english languange. | |
09-23-2005, 18:35 | #13 (permalink) |
Member: 178513 Status: Offline Thanks Meter: 109 | Hi Platijet, Nice to meet You. I cat tell You only this: if You change *ini file to do it i maybe do same if you not do this i not too, ok, look it cerfuly and tell my what other options need to add there, i can , ok? Design is same in aparence, i only use ideas of it. Regards; Albelektronik TEAM |
09-23-2005, 18:46 | #15 (permalink) | |
i can't understand what other ideas you mean.my new version off flasher has also diag area restore(gx15/gx25) and ofcourse i will not share it with anyone because off this. | |
my gx 15 dead after unlock | khabass | Sharp | 1 | 09-04-2008 07:27 |
gx 25 dead after unlock | ::. zine .:: | Sharp | 12 | 04-06-2006 12:45 |
sharp gx 10 i after unlock died | crowgsm | Sharp | 1 | 12-31-2005 16:01 |
SHARP GX-20 dead after unlock w/ REDBOX | totoy | Redbox | 8 | 02-26-2005 13:02 |
Gx 15 dead after unlocking | sonkar | Sharp | 7 | 10-08-2004 09:09 |
